08-11-2021, 08:01 PM | #1 |
Drives: 2010 Camaro SS L99 Join Date: May 2019
Only Driver side vents blowing hot? AC problem
I drive a 2010 SS L99 and recently, when I put the AC on, my driver side vents barely blow and the air is hot.. the passenger side is cold (a little warmer than normal) but still working fine for the most part. I'm assuming some of the plastic ducting(for the lack of a better word) just came loose inside the dash... Does that sound right?
Ever since I bought the car, when I make a hard turn, I heard what sounds like quarters jingling in the vents, but it's never given me problem. Probably not related but figured I'd mention that for just in case that rings a bell for someone. The car has 65,000 miles on it. Any help is appreciated. |
08-11-2021, 08:34 PM | #2 |
Drives: 2013 zl1 vert Join Date: Dec 2018
Broken heater blend door. Good luck
22% lower/ 2.5 upper/ 2” headers/ cat delete/ x-pipe/ 2 gallon x tank/ 100-3 pump/ fic 850/ dsx aux kit/ 103mm throttle body/ RPM 5” intake/ meth kit/ prometh lid injection/FI interchiller/ 160* stat/ ngk-7/ msd wires/ elite catch can/ tsp cam/ Che trunnions/ ported supercharger/ 1/2” lid spacer/ brick mod/BMR toe and trailing arms/ 751hp 757 tq SAE @17.3lb on a loaded dyno.
08-11-2021, 08:55 PM | #3 |
08-11-2021, 09:26 PM | #4 |
YouTube-Car Nation Videos
Drives: 2010 Chevrolet Camaro Join Date: Nov 2019
It’s the blend door. It’s a $3000 repair. Good Luck
08-11-2021, 09:28 PM | #5 |
08-11-2021, 09:29 PM | #6 |
Drives: ABM #93 Join Date: Oct 2018
Or a lot cheaper depending on how you want to go about it.
https://www.camaro5.com/forums/showthread.php?t=568070 This thread gets kinda drawn out but in a nutshell you can cut the side of the hvac box in the car and replace the blend door then seal up the cut piece and be on your way. The door is pretty cheap, the labor to pull the dash and windshield if you don’t do it your self is not cheap.
ABM #2399 2SS/RS:SOLD
ABM #93 2SS/RS Black Rally stripes, Titanium Interior 4,000 miles: GM GFX side skirts and diffuser waiting on paint, GM dovetail, GM heritage, RPI ZL1 style splitter. ‘87 IROC-Z Iroc blue. all original unmolested with 50K miles. Last edited by Aqua Blue RS/SS; 08-11-2021 at 09:44 PM. |
08-11-2021, 09:47 PM | #7 |
I paid $16 for a new blend door and $12 for a roll of Flex Seal tape.
The hardest part is having to live with knowing you hacked up your airbox, but I got over it quick lol.
08-11-2021, 11:03 PM | #8 |
or you could just put a valve in the heater hose line and turn it off for the summer...
08-11-2021, 11:06 PM | #9 | |
08-11-2021, 11:07 PM | #10 |
Yes, I will get over it within about 5 seconds when I remember that I saved 3,000 dollars lol.
08-11-2021, 11:08 PM | #11 |
08-12-2021, 04:30 AM | #12 |
if you turn off the hot water running through the heater core your a/c will be cold again without having to spend a lot of time trying to hack into a spot thats hard to get to.a person did this in the thread heater door hacks ,around 8th or 9th page.
08-12-2021, 06:15 AM | #13 |
Drives: 2013 ZL1 Join Date: Nov 2018
I just fought this battle, was low on freon.
08-12-2021, 08:30 AM | #14 |
Interesting.. thanks I am definitely going to check that out.
