05-27-2019, 01:01 PM | #1 |
Drives: 2019 Camaro ZL1 1LE Join Date: Apr 2019
2019 ZL1 1LE Oil Preference
Hey all. Hopefully there's not another thread specifically on the 2019 ZL1 1LE oil topic (I know 2019 is diff than previous years) because I can't find anything and am not a fan of clogging the forum.
With that said, what oil do all of you 2019 ZL1 1LE owners use? I'm a big fan of Amsoil and am thinking the 0W-40 signature series with their oil filter. Thoughts? Thanks and Happy Memorial Day all 🇺🇸💪🏽
2019 ZL1 1LE
05-27-2019, 01:29 PM | #2 |
Mobil 1 0W40... exactly what's on your oil cap.
This goes for 17 & 18 ZL1s too and Corvette. 15W50 is required for track on the ZL1 1LE and ZR1 only. https://www.camaro6.com/forums/showthread.php?t=522484 |
05-27-2019, 01:31 PM | #3 |
Drives: 23 LT1/22 Colorado TB/69 Chevelle Join Date: Jun 2006
You're going to want a Dexos approved oil if you want keep your warranty and avoid issues if you ever blow it up. If the Amsoil isn't Dexos, I'd stick with Mobil 1 ESP 0W-40.
05-27-2019, 06:26 PM | #4 |
Thanks guys. I am debating between the Mobil 1 and Amsoil Signature Series. This is from Amsoil website..
"Original equipment manufacturers (OEMs) like GM* have addressed the issue by designing tests to determine a motor oil’s ability to prevent LSPI. Signature Series Synthetic Motor Oil achieved 100 percent protection against LSPI1 in the engine test required by the GM dexos1 Gen 2 specification - zero occurrences were recorded throughout five consecutive tests." I'm not sure the difference between Dexos1 Gen 2 vs the Dexos requirement on the vettes and ZL1 1LE's. Any insight on this?
2019 ZL1 1LE
05-27-2019, 09:16 PM | #5 | |
Drives: 2020 SS 1LE (previous: 2017 SS 1LE) Join Date: Mar 2012
Perhaps this will be of help: https://www.camaro6.com/forums/showthread.php?t=552667 If any doubt go on Dexos website. If you dont see the oil listed there in Dexos2 section, then it is not authorized by GM. Cheers! EDIT: Dexos 1 gen 2 is an updated Dexos 1 standard and it is NOT the same as Dexos 2 standard. |
05-28-2019, 09:14 AM | #6 |
Drives: Fastish Join Date: Jan 2019
Don't try to reinvent the wheel here if you want warranty. Run Gm's Mobil 1 and enjoy the car!
05-28-2019, 10:21 AM | #7 |
05-28-2019, 10:28 AM | #8 |
Sell Low, Buy High
Drives: 2022 ZLE, 2023 ZLE (Inbound) Join Date: Feb 2019
Are guys with ZLE's really dumping their 0w40, filling with 15w50 for the track, then dumping the 15w50 and refilling with 0w40 afterward? Seems insanely expensive.
05-28-2019, 10:38 AM | #9 |
Thanks fellas! I've always liked Amsoil but know these engines are very specific so I'll be running Mobil-1 and calling it a day.
Any preferences on oil filters? K&N? Delco?
2019 ZL1 1LE
05-28-2019, 10:39 AM | #10 |
Drives: 1SS Hyper Blue Metallic, MRC, NPP Join Date: Apr 2016
I was under the impression that you could use the Ow40 for both track and street??? Wasn't that the purpose for developing this specific oil???
05-28-2019, 10:52 AM | #11 |
05-28-2019, 02:46 PM | #12 |
Read my thread below titled CAMARO OILS LISTED AND COMPARED for helpful info.
In short, ZL1 1LE should run 0 or 5W40 Dexos2 for street and MUST run SAE 15W50 for track because of sticky tires and aero causing pick up issues with lower viscosity oil. All OTHER V8 Camaros can use 0 or 5W40 Dexos2 oil for BOTH street and track. Or Dexos 5W30 for street ONLY. I suspect most ZL1 1LEs get trailered to/from track given their tires only last up to 3 days (fronts). So most likely have 15w50 in them permanently. Note that given a high SAPS content of this oil any daily driving (which usually doesnt see high operating temps, or worse: mild temps only) would not be best for the motor and defo bad news for cats. |
05-28-2019, 02:48 PM | #13 |
05-28-2019, 03:15 PM | #14 |
