TireRack
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Other Generations > 4th Generation Camaros
Old 01-31-2019, 03:11 PM   #1
SpartanB482
Drives: 2011 Camaro SS LS3
Hard to start 94 Z28
My sister has a 94 Z28, and it has a real problem with dying 2 or 3 times before it starts. It has a brand new fuel pump, so Im thinking its got maybe a weak injector or bad regulator? Has anyone else had a problem like this? You almost have to treat it like an old small block with a carb on a cold day and feather it until it takes off lol
Thanks
SpartanB482 is offline   Reply With Quote
Old 01-31-2019, 04:02 PM   #2
Jeff9962
Drives: 2014 1SS 6M
Quick thing to check is if the system is bleeding down. On your cold start, cycle the ignition switch on and leave it for a few seconds. Cycle it off then try to fire it up. If the problem goes away then the system is bleeding down due to a leaky injector(s) or fuel pressure regulator.
You really need to get a fuel pressure gauge on it though to see what's happening through the whole cycle.
Jeff9962 is offline   Reply With Quote
