11-26-2018, 07:23 AM | #1 |
Drives: 2011 Camaro SS LS3 Join Date: Jul 2018
Driveline Clunk
I have a 2011 SS M6, and when shifting 1st to 2nd I can feel a clunk after I push the clutch in. It only happens 1st to 2nd, and it feels like it's coming from behind the driver seat. Anybody have this problem, or know of anything that could cause something like this? Car has a brand new clutch, throw out bearing, etc.
Thanks |
11-26-2018, 03:33 PM | #2 |
Angewendet Ingenieur
Drives: 14 Camaro ZL1 Join Date: Apr 2015
Carrier bearing?
LQ9, Iron Block, Forged internals, 408CI, Jannetty custom cam, TS short block, Whipple, Hardened Jackshaft, PRC 260, 2X3 Dynatech Full Competition, HF Cats, CAI, NW 103, Chee, ID 1300, COPO Breather, MSD, Fore Dual Pump, ultratorque, E85, dual Meth, True Trac, 3:45, 1500hp axle-shafts, DSS CF, BMR, custom Pearl/Candy paint by Jaidah. |
11-26-2018, 04:57 PM | #3 |
Served USN - Atomic Chimp
Drives: 13 Camaro LSX434 TT M6, 21 ZLE A10 Join Date: Jul 2012
Unlikely with a stock setup, but check rear differential bushing for movement.
In excess of 1,000WHP LSX434 | AGP 65/65 TT | BTR Equalizer Intake | Trickflow 245cc cathedral | BTR custom cam | Cortex EBC | n2mb WOT | ID-1700x | Brisk GR12S | RPM Lv 7 TR6060 | AGP's Triple 525LPH Fore Fuel | Monster LT1-S Triple | 4.11 DSS Proform 9", CF driveshaft, 1400hp axles | Hurst Line Lock | MGW Retro Short Throw w/old skool Hurst T-handle | ADM solid subframe mounts | Prothane Motor Mounts | Revshift Poly Trans insert | Moreno camber/caster plates |
11-26-2018, 08:41 PM | #4 |
11-27-2018, 08:51 AM | #5 | |
GPI Sales Consultant
Rear subframe (cradle) bushings are really soft to begin with in 2010 and 2011s. M6 cars that have been driven hard are going to be REALLY soft by 120k miles. I recommend a solid bushing for the cradle, and a poly bushing for the diff. It will CHANGE the car, clutch takeup becomes much cleaner and smoother, the car will shift nicer, the car will respond smoothly the throttle inputs. One of the mods I've done that I like the most - and I recommend for any M6 car.
Here is a pretty telling video for just how much those things move around.
GPI Max Package 2.0: Brodix BR7 heads/GPI porting, MAX3 cam, ST2116LSR, BSR Max Lift rockers, LS7 LSXR with 103mm TB, Vararam OTR, Mcleod RXT, G-Force/Strange 9" IRS setup with 4.63 gear. 551whp, 11.1@124mph.
Got a question about a GPI product? Feel free to shoot me a message! |
12-09-2018, 02:44 PM | #6 |
Drives: 2015 Camaro SS 1LE Join Date: Feb 2017
Solid is pricey, but the video does not lie. I wonder how a hard durometer poly would do. I mean the billet allows no movement at all. I’d imagine better on the diff since it’s not moving all around
01-02-2019, 01:52 PM | #7 |
Donkey Dick Cam Camaro
Drives: 2010 2SS/RS LS3 M6 Join Date: Oct 2009
im almost 99% sure that its your motor mounts. mine had the exact same symptoms and i went ape shit going through the entire rear drivetrain and suspension without finding anything. it drove me nuts.
then one day when changing the sparkplugs, i noticed that the driver side of the engine cover had wear marks where it had been rubbing up and down on the shield of my aftermarket cai. so i decided to order (2) new ZL1 mounts and a stock TR6060 mount from the dealer. did the motor mounts and problem solved. i did the trans mount afterwards for good measure.
Bone Stock |
01-10-2019, 10:50 PM | #8 | |
Also, since I've been paying more attention to it, I've noticed that the clunk/thud gets harder and louder the more throttle your giving it. If you really try to bang through the 1-4 gears, it's much more noticeable. |
Thread Tools | |
