07-30-2018, 07:49 PM | #15 |
I've never once obeyed a manual about break-in and I've never had brake work done, they don't burn oil, never replaced a clutch or lost a tranny. Break in is a myth...they expect you want it so they give it to you. Same with this Dexos2 oil...give me a break.
05-11-2021, 08:36 AM | #16 |
Drives: 2021 Camaro 2SS Join Date: May 2021
I dont run mine HARD but i do run it harder than break in recommendation, minding not to really keep it running high rpms. My contention is why doesnt the computer govern the car to 4000 rpm for 1500 miles? That would be an easy code to write.It is easy to give it more than you should.
05-11-2021, 10:06 AM | #17 | |
Drives: 2020 SS 1LE (previous: 2017 SS 1LE) Join Date: Mar 2012
On a serious note, the long break in requirement is for an e-diff and confirmed as such right in the manual. Anyone that suggests otherwise, misses a key point here, given a properly operating e-diff is absolutely critical to the car's fantastic handling properties. Most track rats change ediff fluid after a break in period and then again after a first track event. Given a black sludge and volume of metal shavings that come out: it is easy to understand why the break in period. Cheers! |
05-11-2021, 10:23 AM | #18 | |
'20 ZL1 1LE A10,
05-12-2021, 07:25 AM | #19 |
11-14-2022, 09:47 AM | #20 |
Drives: 2023 VOM Camaro 2SS Coupe Join Date: Oct 2022
Will your warranty be voided if you do not follow the break procedure written in the manual?
11-14-2022, 10:04 AM | #21 |
Drives: 2SS 1LE Join Date: Oct 2011
Wow, that guy should get hired as an engineer for GM, he's got it all figured out!
2018 2SS 1LE 2023 Colorado ZR2 2022 Stinger GT-line AWD |
11-14-2022, 11:01 AM | #22 | |
To the poster above, the break in procedure is mainly for the benefit of ELSD vs motor. It is very evident during a first fluid change, which comes out as tar with plenty of metal particles captured by the magnets. That's also why GM recommends to change fluid after the first track day. Beware of "very experienced " tuners, who focus on motors and are not familiar with a complete drive train and their break in dynamics. Will GM void a warranty? Cannot answer this question. But regardless, why potentially eff things up regardless who pays for it? Cheers! |
11-15-2022, 02:19 PM | #23 | |
So according to OP's original post, an oil change at 500 miles is needed, but it does not say anything about changing it again at 1500. Is an oil change needed at 1500 miles if you are not tracking it? Also, that document disagrees with the manual about the number of miles where you shouldn't exceed 4K rpms (500 vs 1500). Which is correct? Lastly, it says nothing about not going over 80 mph like the manual does. Again, is this document correct or the manual? |
11-15-2022, 04:38 PM | #24 | |
Drives: 2023 Summit White Camaro ZL1 M6 Join Date: Dec 2021
2019 Dodge Durango R/T (daily driver) 2003 Nissan 350Z (modified) 2022 Rapid Blue 1SS 1LE M6 (delivered 2/19/22) (Sold) 2009 BMW 135i (Sold) |
11-15-2022, 09:07 PM | #25 | |
11-16-2022, 06:28 AM | #26 |
Thanks for the replies ZPirate and TrackClub!
I agree that it is a small price to pay to go through the full 1500 mile break in period to ensure good performance throughout the life of the car. My questions were aimed at learning the best way to break in my new SS (not a 1LE and will not be tracked), but I see your points that there are differing opinions on that issue. My guess is that even if it is overkill, it cannot hurt the car to keep it below 4K rpms and 80 mph for the first 1500 miles. Cheers! |
11-16-2022, 07:33 AM | #27 |
Drives: 2022 2 SS 1LE on order ....now a 23 Join Date: Jan 2022
Well if it was that simple everyone would just follow the directions. The kicker is engine builders say you have to set the rings the first 500 miles so thats one of the concernes I have seen. I think I will do a few high rpm pulls to make sure. Others will say your voiding your warranty. Its a real head scratcher for sure...lol
11-16-2022, 08:10 AM | #28 |
Thank you Al Oppenheiser!
TL/DR: give it the beans a couple times before 500 miles, and then change the oil.
Going easy on the differential for the first few hundred miles is a good thing. Taking the car to the track straight from the dealer lot with 100 miles is gonna do more harm than good. Let the asperities on the gears smooth out a bit and build up a good work hardened mating surface before you start blasting 'em with full torque. The metallurgy has changed for the better, but surface physics has not. It's not too much unlike breaking in old style flat tappet cams... had to go easy at first to let the metal work-harden, and if you didn't you ground it to dust; and sometimes it just happened anyway.
Now this is the opposite of what you want to do with the rings and cylinders. You want the asperities removed and metal hammered flat BEFORE it hardens (the metal is different so it needs different treatment). Granny-driving the engine at low RPM for the first 1500 miles is not what you want to do. I recommend you look up the crate motor break in guide (oh here it is!) and follow the directions starting at step # 6. Steps 1-5 were done for you by the factory. IMO, one oil change at 500 miles is sufficient (not both). Last edited by Gunkk; 11-16-2022 at 08:33 AM. |
