08-26-2022, 07:44 PM | #15 |
Drives: 2022 ZL1(FEA suspension) Rapid Blue Join Date: Apr 2019
08-26-2022, 09:48 PM | #16 |
Drives: 2020 ZLE A10, 2018 F250 Diesel Join Date: Apr 2020
08-30-2022, 08:12 AM | #17 |
Drives: 2018 Camaro 1SS 1LE Join Date: Jun 2021
My dilemma is that I still need a back seat for my kid.
AND Some of the clubs I run require a HANS device for advanced groups. I’m not a huge fan of the hybrid, so for me a 4PT belt + HANS III is the happy medium. This way I keep my back seat, I have a HANS and I can run advanced groups. |
08-30-2022, 05:09 PM | #18 |
Drives: 2022 1SS 1LE A10 BCD WCT+PDR Join Date: Mar 2008
I did a 6 point and slotted my Recaro on my '14 SS 1LE. If it helps here's the link with some info:
https://www.camaro5.com/forums/showthread.php?t=599988
08-31-2022, 12:12 PM | #19 | |
I too was looking to up my safety gear and setup as I also run in an advanced group. What I was advised by folks that know was you do it all or do none of it. Modifying the factory systems makes it less safe. I was also told the HANS device isn’t needed with factory seatbelts and could even be dangerous with an airbag. |
08-31-2022, 12:35 PM | #20 |
i have sparco seat half cage seat delete 6 point harness and a necksgen hans device
still have the stock seatbelt also but i never use it
08-31-2022, 02:16 PM | #21 | |
08-31-2022, 06:05 PM | #22 |
I run the Simpson Hybrid S with my OE 3 point. I believe it is the only head and neck restraint spec'd for use with OE 3 points and 4,5,6 point harnesses. Remember, air bags are calibrated for non-helmeted noggins. Adding a helmet adds weight. There is no harm in using one.
11-27-2022, 05:04 PM | #23 | |
Drives: 2018 SS 1LE Hyperblue Join Date: Jul 2017
Thanks! |
