01-22-2020, 06:47 PM | #1 |
Drives: 2016 Camaro SS Join Date: May 2018
Camshaft Position Sensor V6 Location?
Hi guys, I just had an engine light appear on my dash and after I ran the codes at the Chevy dealership it came back to a camshaft position sensor. (OEM Part #12646782) It's only a $35 sensor and I would like to fix it myself instead of getting ripped off at the dealership especially since I am out of warranty, however, I have no clue where the part is located on the engine. If anyone can help or if someone has a picture that would be even better. Thanks guys!
02-29-2020, 08:17 PM | #2 |
Drives: 2017 SS1 Red Hot Join Date: Apr 2017
Did you ever find the location? Mine went bad too.
02-29-2020, 11:05 PM | #3 |
Attachment 1021699
Yes, there are 2 located on the back left and right side of the engine. Was really easy to replace. One is located in the red circle, that should help give you a ballpark on the location. The sensor looks like the one down below. Last edited by BlueVelvetCamaro; 02-29-2020 at 11:09 PM. Reason: Better Photo |
02-17-2023, 07:42 AM | #4 |
Drives: 2017 1LT Camaro Join Date: Jun 2019
This is the first response I've seen where someone says they are located in the back. A few videos and posts say they are located in the front. Camshaft and crankshaft sensors. They've recommended replacing all four. Just like to clear things up, because I'm having a P0020 code. I would really like to know the exact location and part number. Any further input would be great.
Here's a video that I believe shows the location of all four sensors for VVT. https://www.bing.com/videos/search?q...A&&FORM=VRDGAR |
02-17-2023, 09:28 AM | #5 | |
02-17-2023, 10:45 AM | #6 |
I responded in your other thread:
https://www.camaro6.com/forums/showp...33&postcount=3 |
02-17-2023, 11:55 AM | #7 | |
Tags |
camshaft position sensor |
