Old 01-17-2020, 06:57 AM   #1
avarshav
avarshav's Avatar
Drives: 2020 SS 1LE 6M, 2019 GMC Canyon SLT
whats that sound when you open the door on a 20 SS 1LE?
So, probably stupid question, but I'll ask anyway cause it has me intrigued.
So, if my car has been sitting off for a while, and I go open the door, there comes this hum and buzz from the rear of the car for about 5-10 seconds and then it stops. fuel pump, something with the mag ride? no idea and it seems normal, but I'm just curious as to what the heck it is? I had a 2017 V6 2LT before this one and it didn't do it, nor has another other car I've ever had in my life.
avarshav is offline   Reply With Quote
Old 01-17-2020, 06:59 AM   #2
ZL1 1LE
@zle_blackwing
ZL1 1LE's Avatar
Drives: 2018 ZL1 1LE
Fuel pump priming.
Old 01-17-2020, 07:00 AM   #3
avarshav
avarshav's Avatar
Originally Posted by ZL1 1LE View Post
Fuel pump priming.
thanks! never had a car that did that before!
Old 01-17-2020, 01:40 PM   #4
Mov Ov3r
What speed limit?
Mov Ov3r's Avatar
Drives: 2017 SS 1LE
That my friend.. is the sweet succulent sound of the car preparing to ignite the wonderfully tasty nectar your V8 needs to send the screaming bald eagles furiously from the 4 pipes out of the rear of your vehicle
(or what ZL1 1LE said)
Mov Ov3r is offline   Reply With Quote
Old 01-17-2020, 02:35 PM   #5
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '21 ZLE A10
my 13yr old asked the same question the other day...my truck does the same thing. DI fuel pump prime. Older fuel injected cars prime when the key is turned to "ON" before starting.
Old 01-17-2020, 05:56 PM   #6
Warrior102
Warrior102's Avatar
Drives: 2018 2SS 1LE Black
The in tank pump supplies fuel and primes the high pressure pump so it doesn't cavitate when the engine is started, the HP pump is driven by the engine. The car has several fuel pumps being direct injection, normal noise..
Warrior102 is offline   Reply With Quote
Old 01-17-2020, 07:15 PM   #7
nancygrl
雪の玉
nancygrl's Avatar
Drives: '22 Z71 RST Silverado
Fuel pump priming.... My previous '16 and '17 SS's would only do that when opening/unlocking the driver door only. On my '19 not only when either door opens and it happens when unlock doors via remote, heck it even primes when opening the trunk. Quite normal.
nancygrl is offline   Reply With Quote
Old 01-17-2020, 07:24 PM   #8
Aragorn
Drives: Camaro SS 1LE
I swear I had a 2004 1.8t Jetta that did that.
Aragorn is offline   Reply With Quote
Old 01-17-2020, 07:49 PM   #9
ST1LE
ST1LE's Avatar
Drives: E92 BMW M3
HAHAHA YES!
J-Rod Built and Matt@FSP Tuned
ST1LE is offline   Reply With Quote
Old 01-17-2020, 09:51 PM   #10
RUQWIKR
RUQWIKR's Avatar
Drives: 1LEs
GM added it due to complaints of long crank times.
RUQWIKR is offline   Reply With Quote
Old 01-17-2020, 09:51 PM   #11
Uncle Sam
Drives: 2017 Camaro 1LE Hyper Blue
My Triumph motorcycle will "hum" with the ignition on - fuel pump for the FI.
The sound I notice from the back is the electric parking brake on the SS.
P.S. I don't like electric parking brakes.
Uncle Sam is offline   Reply With Quote
Old 01-18-2020, 11:24 AM   #12
ZL1 1LE
@zle_blackwing
ZL1 1LE's Avatar
You said it much better than I did.
Old 01-18-2020, 11:37 AM   #13
avarshav
avarshav's Avatar
yup, you get the best quote of the day!
damn I love this car. I bought it the day before thanksgiving, have 600 miles on it so far, smiling my a** off with a s**t eating grin every mile of the way.
Old 01-18-2020, 07:20 PM   #14
JROC
Drives: 19 Camaro SS 1LE, 03 Ford Lightning
I figured it was the fuel pump/pumps (however many pumps these cars have) priming. How long does the car have to sit between priming? If the car isn't cold or been sitting for a while I haven't noticed it priming.
JROC is offline   Reply With Quote
