11-28-2019, 03:53 PM | #1 |
Drives: none Join Date: Jul 2011
455 horsepower? not enough! 30 miles on the clock? Time to supercharge!
Note: This project is an open and blank canvas, suggestions welcome. If you have real technical knowledge or lessons learned, please post!
Supercharging project for a brand new 2019 Camaro (2019 because it's discounted and black because the front end of these model year cars leaves a little to be desired...) My intent is to push hard to 750 hp on the first build, and then ease up to 4 figures with upgrades. car: 2019 lt1 1le with 2ss pkg and 30 miles on the clock. I drove it home and began the teardown. If you want to jump in with a warranty comment, tuck it way down deep inside. Way down. I am the warranty. Plans? open, but I am leaning toward a Whipple. i like the concept of efficiency! 1000 crank HP goal Bottom end? looking at a reasonably priced home-built forged setup. Drop in pistons, rods, and rings are a possibility, but right now I am thinking fully forged crank, rods, pistons, balanced from the seller, and it will be at the stock cubic inches. I am also considering a compression ratio less than 10:1, but I would like to maintain squish features, flame front concepts for efficiency. If anyone has comments on whether the cylinders need a honing after those first 30 miles, please post! I am inclined to have the block fully inspected and dimensioned to identify potential problem areas. Cam? please provide input! I will be seeking streetable boost cam that will meet my horsepower goals and my inclination is a lift less than .600. I have run the donkey cams , have seen the decreased life associated, and prefer to avoid. In fact, it will probably be a Comp custom grind. Oh, and I will be adding a camshaft with an increased fuel profile. 116 LSA? Duration 228/236? ICL? Forthcoming! Porting? I'm unsure as to committing, as this has been a major project staller in the past as I can tend to procrastinate. If I port, I will be doing a simple job (casting edges, short side radius, etc....) and I will not be porting cylinders 7 and 8. Ill put in maybe an hour per cylinder. Short and sweet! I would prefer to avoid big price and big flow heads. I am a big fan of polishing the combustion chambers to reduce deposits and delay premature detonation due to buildup. This may be the only part I do, lol. A few cartridge wheels and a 15 min per, voila! Fueling? How far will an lt4 in-tank fuel pump go? What is a better starting frame of mind if i intend to hit 4 figures? Rocker arms? Stock will be shipped for a trunion upgrade, unless there is a smarter idea? Headers? Is 1 7/8 enough? I am thinking purchasing headers that are coated first as a priority, and stainless as a secondary consideration. manufacturer and suggestions welcome! Some purchase pics in following and upcoming posts! Last edited by danf1000; 11-29-2019 at 07:35 PM. |
11-28-2019, 04:29 PM | #2 |
11-28-2019, 04:30 PM | #3 |
current progress
11-29-2019, 10:59 AM | #4 |
I like the gutsy approach, hope you can pull this one off
There was a good point in the other thread you started, the wheel/tire combo you are planning to use. Unless this is an all-out drag racing build, I don't know of anything that can put down the amount of power you want in a RWD setup and still be usable on the street. Heck, even my measly 560 rwhp takes drag radials, no "normal" street tire can handle it. So what's the plan there?
11-29-2019, 04:54 PM | #5 |
itll probably end up with a drag radial on it for those moments where I wanna pull from a dig. To clarify, I will probably limit the final to 850 wheel, or approx 1000 crank.
any thoughts on my approaches or insight on best methods/hardware? |
12-24-2019, 05:20 AM | #6 |
Heads off, pressing toward a full forged build. my idea is to go fully forged with lt4 pistons, if they fit
Is there a recipe for lt4 pistons, lt1 crank, and forged rods out there? my question now is will lt4 pistons require balancing a lt1 crank. I prefer a stock fit piston that is quieter? Also, I would like to get aftermarket forged rods. Are there drop-in rods for an lt4? whats the solution for a fully forged lt1 with lt4 pistons? https://imgur.com/rynEvBe Last edited by danf1000; 12-24-2019 at 05:39 AM. |
12-24-2019, 06:56 AM | #7 | |
12-24-2019, 12:40 PM | #8 |
both of those solutions do not offer selectable compression, but tsp does. id much rather not have to use meth, but a port injection setup that cools the pistons down sounds smart....
https://www.texas-speed.com/p-5584-t...lt1lt4l86.aspx -20cc pistons are selectable with wiseco pistons! thanks in advance! |
12-24-2019, 01:18 PM | #9 | |
12-28-2019, 01:13 PM | #10 |
OK, all, having a tough time getting that upper bolt from the manifold/exhaust connection on the passenger side. oil filter is kinda in the way but it aint the deal killer. It's a closed in area between the firewall and the bell housing, oxygen sensor, etc... im thinking a shorty wrench would break it.
anybody got a suggestion? |
12-28-2019, 01:23 PM | #11 |
maybe a crows foot? attached to a long extension? Thanks in advance!
