Old 10-11-2018, 12:53 PM   #1
Sledgehammer70
Lethal Camaro
Sledgehammer70's Avatar
Drives: 16 2SS, 71 Std, Suburban RTS
Front Facing Camera for Mylink! 8" Screens Only.
Added the Gen5DIY front facing camera to my 2016 Camaro SS. The install is quick and it works pretty easily. All in for the module update and camera is about $600ish. Not only do you get the Camera, but it will turn back on the option to play videos and unlock all motion locks.
Product: http://bit.ly/2yeePqB
Sledgehammer70 is offline   Reply With Quote
Old 10-11-2018, 08:52 PM   #2
OVERPAR73
2018 Garnet Red ZL1 conve
OVERPAR73's Avatar
Drives: 2013 & 2018 ZL1 vert
Still waiting on Ofer to get the harness fixed so it works for the 2018 ZL1.
Build Thread: 2018 ZL1 Vert Purchased (Overpar73)
OVERPAR73 is offline   Reply With Quote
Old 10-12-2018, 02:33 PM   #3
srcstc
Is it 100% reversible? ie can I remove it for warranty work and it doesn't leave a trace?
srcstc is offline   Reply With Quote
Old 10-12-2018, 02:35 PM   #4
Baldman
EMERALD COAST CAMAROS
Baldman's Avatar
Drives: None
The video was almost 30 minutes but what was the actual time it took you to install it?
Baldman is offline   Reply With Quote
Old 10-12-2018, 03:01 PM   #5
MANNAXMAN
MANNAXMAN's Avatar
Originally Posted by Sledgehammer70 View Post
Added the Gen5DIY front facing camera to my 2016 Camaro SS. Not only do you get the Camera, but it will turn back on the option to play videos and unlock all motion locks.
Did you consider the NavTool GMBOX3.0 add-on module? From what I've read, it adds most, if not all, of the same features/functions as the Gen5DIY HMI update without having to send in your HMI. If you considered the NavTool unit, why did you go the Gen5DIY route instead?
1996 Camaro Z28 with T-Tops (Sold 10.22.16)
1986 Camaro IROC-Z with T-Tops (Sold)
1961 Volkswagen Beetle with Sliding Ragtop Sunroof (2009-Present)
1964 Volkswagen Beetle with aftermarket Sliding Ragtop Sunroof (Sold)
Follow me on Instagram - @gen6_2ss_vert
MANNAXMAN is offline   Reply With Quote
Old 10-12-2018, 03:25 PM   #6
DWR
DWR's Avatar
Drives: 2018 Camaro SS 1LE
This question exactly
Originally Posted by fastball View Post
Since 1967 kids all over America have bought the Camaro for the good old American way: loud and fun.
2007 Toyota Corolla S -- Traded
2007 Colorado I-5 3.7L z85 2wd ext. cab --Totaled
2004 Silverado single cab 4.8l v-8 2wd -- Traded
2018 Camaro SS 1LE -- Current DD
DWR is offline   Reply With Quote
Old 10-13-2018, 11:14 AM   #7
Joshinator99
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
Has anyone else done this NavTool box? Seems like a great deal, and plug-and-play?
Old 10-13-2018, 11:35 AM   #8
vtirocz
vtirocz's Avatar
Drives: 2017 Camaro 1SS M6
I’d like to know this as well.
2017 Camaro 1SS, M6, Hurst shifter, Hyper Blue, NPP, Gray Split Spoke Wheels
Best 1/4 Mile: 12.24 @ 115.9 mph
Old 10-18-2018, 02:15 PM   #9
Sledgehammer70
Lethal Camaro
He has the harness done.
Old 10-18-2018, 02:34 PM   #10
Sledgehammer70
Lethal Camaro
100% reversible.
If I followed the instructions and did it there way probably just over an hour. If you notice my videos don't cut a lot of the work, I try to show everything including my frustration and issues.
I looked into it as the cost was simply not something I could over look. But all my research has shown these units simply do not last. Also their offering requires 2 products to do what the Gen5DIY setup offers. Their descriptions are very vague and from the info I found, you can't do everything you want.
The benefit of the Gen5 system is it uses all factory stuff to run everything. Yes the upfront cost can be expensive if you don't send in your HMI, but once you get the new one and send your old one in, you get that refund.
This is a plug and play setup as well for the most part.
Old 10-25-2018, 08:27 PM   #11
OVERPAR73
OVERPAR73's Avatar
Got my front camera harness yesterday and got it partially installed. My HMI area looks different than Lethal Camaro's area when he was installing his. I have asked Jarod for any help. Installation instructions would be really nice. Well see what happens?
Old 11-09-2018, 02:37 PM   #12
OVERPAR73
OVERPAR73's Avatar
Front Camera Kit
Well, I finally received my reprogrammed HMI and swapped it into the car and got, "Theft Detected" warning on my info screen in big red letters. So that didn't work at all. Tried swapping them back and forth several times with no luck. So I have sent both the new HMI and my old HMI to the programer today to see if it can be redone and fixed? I'm guessing I'll have to wait another week before I receive it back and try it all over again. I was told by Jarod at Gen5DIY.com that my car is the first 2018 ZL1 to have the front camera kit installation. It took a little while to get everything after they tested the new harness on Ofer's car. I'll let everyone know how it works out and provide some pics and or video.
Old 11-09-2018, 02:49 PM   #13
2SSRS@Gen5diy
2SSRS@Gen5diy's Avatar
Drives: 2014 Z/28 #82+#192, 18ZLE 66Nova
Hom we have the first 18 ZL1 with the kit, it is a 1LE but still the ZL1, you and us have the PDM unit down there that the 16 we shot the install with did not have, last thing we fixed the video switch used in the kit, so no more warning when it used.
2SSRS@Gen5diy is offline   Reply With Quote
Old 11-21-2018, 07:14 PM   #14
OVERPAR73
OVERPAR73's Avatar
Front Camera Kit from Gen5DIY.com
Ok guys, finally got my original HMI reprogrammed and returned back to me today. Took a little longer than I expected to get it back but just got it installed and everything works perfect now! So nice being able to touch the info screen for the front camera option and seeing what's in front of you. Placed the camera at the very bottom of the grill, you can hardly tell it's there. I highly recommend this mod to all Gen6 Camaro's to prevent damage to your front splitter while trying to park. System will for sure pay for itself if you have to replace your splitter.
Ofer at (Gen5DIY.com) is having some really good prices during their Black Friday sale. I also just purchased their plug & play eyebrow light harness today (on sale). It keeps the eyebrow light on all the time, even with the turn signal blinking. Make sure to check out all their products!
Now I will be removing my front bumper to add the Oracle lighting kits.
