Old 09-24-2018, 11:18 AM   #15
gump
Drives: 2019 CRC 001
Tied down for a trip to the dyno!
Note: For those that are new to towing race cars, always make an "X" with your straps (front and back).
Name:  Tie Downs_1.jpg
gump is offline   Reply With Quote
Old 09-24-2018, 11:20 AM   #16
gump
I finally weighed the car with the cage installed. This is with a full tank of gas (3600 lbs).
Old 09-25-2018, 03:17 PM   #17
gump
Today we ran the car on the dyno at Tick Performance.
Old 09-25-2018, 03:30 PM   #18
waterman
waterman's Avatar
Drives: Grandad's C2 L89
Great thread! Following.
2018 ZL1 1LE sw/PDR
Old 09-25-2018, 03:42 PM   #19
danhr
BAMF SS
danhr's Avatar
Drives: 2016 Camaro 1SS A8
Send a message via AIM to danhr
Subbed.
2016 1SS A8: FBO + Circle D + P1X + Meth + Tuned by Pray Performance
Stock Longblock
800 SAE rwhp. 9.4 @ 145 mph.
Old 09-25-2018, 04:58 PM   #20
GooseSS
Drives: 2018 Camaro SS
Subbed
GooseSS is offline   Reply With Quote
Old 10-17-2018, 12:49 PM   #21
gump
The modifications have begun!! It took about 4.5 hours to get the old exhaust off. No drama. Both manifolds came out through the top.
We are using the Chevrolet Performance/ARH headers (Part Number CAV8-161783000LSNC) and Chevrolet Performance exhaust kit (Part Number 84028865). The mid pipes came from American Racing Headers.
Old 10-22-2018, 12:37 PM   #22
gump
I just installed the passenger side header. Thirty seven minutes from start to finish. It went in from the top after a few items, including the starter, were moved out of the way.
Name:  Passenger Header.jpg
Name:  Passenger Header After.jpg
I like to use a little of this stuff on all the fasteners that are going into aluminum.
Old 10-24-2018, 09:05 AM   #23
gump
After work yesterday I installed the driver side header. The work was a little more involved and took almost three hours to complete. Once again, the fit is very good.
Name:  Driver Header.jpg
(DISREGARD THIS. JUMP TO POST #81 FOR A FASTER WAY!!)
The motor mount has to come out. This one item took the majority of my time. There are four bolts that attach it to the block. Three are easy to get to. The last requires extreme patience to remove and install. But, I am living proof that it can be done!
Name:  Motor Mount.jpg
The steering shaft also had to be removed. It is pretty easy to work with. The main thing is to not move anything when you have the shaft out. It is possible to miss align the clocking mechanism for the air bags. So, care has to be taken here.
Name:  Driver Steering.jpg
Name:  Driver Header After.jpg
Old 10-24-2018, 10:16 PM   #24
laynlo15
laynlo15's Avatar
Drives: 2022 Lt1 A10
I would consider installing the BMR tubular motor mounts. Save about 8 lbs and more room for the headers. Matt installed mine today when he put the new motor in. .
Old 10-25-2018, 06:40 AM   #25
gump
That might be an option at a later date. For now I am sticking with the catalog parts. Chevrolet has put together a combination of parts to create a reliable car that can be daily driven and also show well at a local dragstrip.
Obviously, I have added safety equipment and removed items that most would not. This is a test car that will see a lot of changes. So, a lot of these deletes just make life easier for me when I am working on the car.
Old 10-25-2018, 08:39 AM   #26
Are you tuning?
Old 10-26-2018, 08:29 AM   #27
gump
Are you tuning?
We will be back on the dyno soon. This will be my first time working with a factory ECU. So, it should be interesting. I will post the results.
Old 11-19-2018, 09:13 AM   #28
gump
The exhaust is in! I am looking forward to getting back on the dyno. The installation was pretty easy and took about an hour. The car sounds much better!!
The Chevrolet Performance mufflers require a special mid pipe. Make sure you specify exactly which mufflers you have when placing your order with ARH. These are side-by-side images showing the difference.
