Old 04-14-2017, 11:35 PM   #15
SSport16
SSport16's Avatar
Originally Posted by Nor Cal ZL1 View Post
Your going to love it. Don't fear trying different dilution ratios, pretty thick stuff. Be sure to shake it before use, and after diluting as well. Effective in all uses, most economical in rinseless use.
Will do, thanks!
Old 04-15-2017, 07:04 AM   #16
SimMan
SimMan's Avatar
Drives: 2011 SIM Convertible
Send a message via Skype™ to SimMan
has anyone tried the "Top Coat" product?
SimMan is offline   Reply With Quote
Old 04-15-2017, 09:52 AM   #17
Nor Cal ZL1
Nor Cal ZL1's Avatar
Drives: 2013 ZL1 M6
No. I see this question pop up often because it is being pushed on Facebook.
There are very few reviews online, none of the professional sites are carrying it, general opinion is its hype in the detailer circles. Many products are. I can't say it is good or bad, but for an unknown product, it is massivly expensive, and there are no where ear enough legit reviews for me to consider it as a viable product.
Nor Cal ZL1 is offline   Reply With Quote
Old 04-15-2017, 09:59 AM   #18
Glen e
Retired from Car mfrs....
Glen e's Avatar
Drives: 2LT RS/HR-V
Exactly what I have heard too.....
Old 04-15-2017, 11:00 AM   #19
ToadMcFrog
Drives: '17 2SS
Glen, are you using anything as a "drying aid" (a quick detailer or otherwise) when drying after using ECH20? I think I remember you saying at some point that you used something while drying after using Duragloss, but I could be totally misremembering.
ToadMcFrog is offline   Reply With Quote
Old 04-15-2017, 11:08 AM   #20
Glen e
Glen e's Avatar
Drives: 2LT RS/HR-V
No you're right I used duragloss aquawax as a drying agent. But I wash about every 10 days and I found no need to add more products to the finish. I won't use the echo2 the same way.....but certainly some do....
Old 04-15-2017, 11:23 AM   #21
ToadMcFrog
Drives: '17 2SS
Thanks, Glen - it's good to know that I wasn't losing my mind at the very least! I think I'm going to order some ECH20 and give it a whirl.
Old 04-15-2017, 03:56 PM   #22
SSport16
SSport16's Avatar
You shouldn't need anything else with a Silica product for rinseless washes, but I get it all depends if you want to really soend more time and $ on another product not really needed.
Old 04-16-2017, 09:11 PM   #23
Nor Cal ZL1
Drives: 2013 ZL1 M6
I use the Ech2o detail mixture as my drying aid. The little reload, or cure mixed in works very well. But for rinseless there is not much need, though I mist each panel with the mix before drying. Once dry your done. You can skip it if you like. I like the added lubrication as a safety margin.
Old 04-16-2017, 09:38 PM   #24
SSport16
SSport16's Avatar
Is that the quick detailer mix for the Ech20 as per the bottle ratio or is that the one with Reload and Ech20?
Old 04-17-2017, 03:46 PM   #25
Nor Cal ZL1
Drives: 2013 ZL1 M6
I use it only with cure or reload. It should be ok without. Hit a panel with a few light mists and see how it released the water beads. Im always really busy so I like the custom blend as a step saver.
Old 04-17-2017, 04:50 PM   #26
SSport16
SSport16's Avatar
Gotcha, thanks...my Ech20 was delivered today, can't wait to try it out.
