Old 08-01-2018, 02:25 PM   #1
Evil-Bee-NH
603 Camaros
Evil-Bee-NH's Avatar
Drives: 2017 NGM I4 1LT Coupe
Ghetto Drag Setup?
So i bought 275/40/17 on a 17x9 and now need to do the front either 17x8 or 17x7.5 what tire size should i run to avoid ABS issues with wheel speed?
Old 08-02-2018, 06:00 AM   #2
wnta1ss
Drives: 2017 Camaro 1SS
I have some drag radials in 275/40-17 and my SS has done some weird stuff with this size on back and some 245/40-20 front tires. Finally got to try some 26" diameter front tires for my most recent trip to the dragstrip and the computer seems happier with them. My suggestion for your drag pack is to use a front tire that is as close in diameter to those rears as you can.
Old 08-06-2018, 07:23 AM   #3
Eyefixstuff
Eyefixstuff's Avatar
Drives: 16’ 2SS A8 HBM Procharged
A 255/45/17 front puts you very close to the same diameter, and a little less than an inch less in width. If you are running that rear tire then that’s what I would go with.
You may have traction issues though. That rear tire comes in around 25.7 inches which is pretty short and I’m betting you will likely have a hard time with your 60 foot because of it. Typically with the auto you want a 28” tire from what I have read and tried myself. Let us know how it works out.
16' 2SS A8 Hyperblue | P1SC-1, Race IC | JMS fuel pump voltage booster | Jannetty custom tune | Elite E2-X catch can | M017 Wheels
Eyefixstuff is offline   Reply With Quote
Old 08-06-2018, 07:41 AM   #4
danhr
BAMF SS
danhr's Avatar
Drives: 2016 Camaro 1SS A8
Send a message via AIM to danhr
BFGoodrich g-force sport comp-2 tires come in 215/50/17
That's a 25.51" tall tire, so it shouldn't mess with your ABS with your 275/40/17s
it's also almost as "skinny" as you can get on a 7.5" wheel. It won't fit on an 8" wheel
2016 1SS A8: FBO + Circle D + P1X + Meth + Tuned by Pray Performance
Stock Longblock
800 SAE rwhp. 9.4 @ 145 mph.
Old 08-06-2018, 12:16 PM   #5
2SSVERT
2SSVERT's Avatar
Drives: 17 garnet red 2ss vert
I tried some 315-35r17 Hoosiers on my 17 ss. Car dead hooked on a unpreped track but it computer did not like it. Messed with the anti lock and traction control. Turning off traction control fixed that but had to live with the antilock brakes cycling after a run, more of a annoyance then anything.
2SSVERT is offline   Reply With Quote
Old 08-06-2018, 07:07 PM   #6
wnta1ss
The OP has a turbo 4 cylinder with 329 lb/ft of torque. My thinking is he'll probably be ok with a 275/40-17 drag radial. I say that because I've recently used such a tire on my SS with a supercharger, on the same track he will be running on. My supercharger is a centrifugal, so it does not hit particularly hard off the line with the stock torque converter, but still it has done 1.6 short times on the few runs that I've made so far with a drag pack and the supercharger this summer. Possibly a harder hit (from an aftermarket converter or a positive displacement/screw blower) might require a taller sidewall on an SS.
Old 08-06-2018, 08:46 PM   #7
Evil-Bee-NH
603 Camaros
Went with the 245/45/17 for the front hoping to get to the dragstrip this week and work into the 12s and in the fall hopefully low 12s.
Old 08-07-2018, 08:10 PM   #8
Dustya
Drives: Overkill Supercharged 2016 CamaroV6
Awesome man keep us updated !!!
Hyperhawk - 2016 Camaro 2LT RS - First LGX in the 12's and 11's Current record holder 11.0@125
Follow me on Instagram https://www.instagram.com/hyperhawkcamaro/
Youtube https://www.youtube.com/channel/UCHR...-ilSpV3gMQnTuA
Supercharged with Overkill Superchargers http://www.v6superchargers.com
Dustya is offline   Reply With Quote
Old 08-08-2018, 07:23 AM   #9
Evil-Bee-NH
603 Camaros
I'm putting down 296whp/352wtq right now and that was after 2hrs. of dyno and road tuning in 80 degree mildly humid weather. I'm averaging 13.2 to 13.3s passes over the past 3 track visits so I'm really interested to see what going from a 20" street tire to a 17" DR will do. Also the individual wheel weight difference is just over 20lbs. Less in the rear.
