07-11-2018, 10:50 PM | #1 |
Tactical Garage
Drives: 2016 Camaro 2SS Join Date: Nov 2016
Changing from Pump Gas to Race or E85
For those of you changing between types of gas how are you draining the one type and switch to the other? I want to run pump gas on the street and race gas at the track but from what I heard it is a pain to get the fuel out of the tank. Someone told me that there is a easy way to do it if you have DSX Aux Fuel pump I am considering this route but I don't think most people switching back and forth have this. Or are you just run the tank low and switching with a mix of gases? Or??
Curious how people are dealing with this? Thanks for the input. |
07-12-2018, 04:56 AM | #2 |
Probably going to have to purchase HP tuners and have two tunes as I do.
07-12-2018, 09:21 AM | #3 |
Tactical Garage
Yep, I got the idea from reading your other posts. I have the HP tuners. How are you changing between pump and race gas?
07-14-2018, 09:28 AM | #4 |
Drives: '17 Red hot 2ss, 16 Focus RS Join Date: Aug 2015
Is there a way to turn the pump on continuously? I used it to drain once and could only find the option to prime which only runs the pump 2-3 seconds. Luckily I only had 1.5 gallon to run!
"Spitfire" 427ci
2017 Red Hot 2SS// 6 Piston Brembos//Adrenaline Red Interior, Knee Pads//M6//MRC Afe Air Filter//BMR MM010 Motor Mounts, Safety Loop//Custom OTR Intake//Flex Fuel Kit//Gforce 3.5" Aluminum Driveshaft//GM 95mm TB//Katech Oil Pump, Piston Squirters//Kooks 1-7/8 LT//LT4 Fueling//Mighty Mouse Wild//Monster Clutch LT1-S Triple Disc//MSD 2-Step//Pray Performance Custom Spec Cam, Ported Holley Hi-Ram//Sikky 12" Shifter w OEM Knob Mod//Tick Level 1 Tr6060//Labor by Me//Tune By Pray Performance |
08-04-2018, 06:34 PM | #5 |
I used to just run mine down to below an 1/8 on 93 and dump in the MS109, change the tune and your good to go.
08-12-2018, 08:46 PM | #6 |
Drives: 2017 Camaro 2SS Nightfall Gray vert Join Date: Jan 2018
For E85, I figured that you could just switch to e85 whenever you feel like it. The tune will automatically adjust based on the ethanol content%...with the most power coming as close to e85 as possible.
With race fuel, I hadn't thought about needing a different tune...@laynlo, so you just switch the tune for track and street?
Magnuson Heartbeat SC - Tuned by JRE Racing 776whp/745wtq (12psi) 2018 Corvette Z06 vert- Black To be tuned by JRE Racing TBD performance |
Thread Tools | |
