07-03-2018, 08:59 AM | #1 |
Drives: 16’ 2SS A8 HBM Procharged Join Date: Jun 2017
Launching and shifting the A8 at the track
Hi all. Now that I have switched to an A8 I have a couple of questions before I bring it to the track later this week.
How are you launching? What mode? Foot on brake and load it up, or just mash it from idle? How are you shifting? Leave it in drive and let it do it’s thing or do you use the paddles? Do the different modes change what RPM and how hard/fast it will shift? Sorry I am sure these questions have been answered before but I can’t find anything specific for a car that is FI and running a drag pack. What works best for you? Thanks! (A8 with MRC, procharged, drag pack, full weight.)
16' 2SS A8 Hyperblue | P1SC-1, Race IC | JMS fuel pump voltage booster | Jannetty custom tune | Elite E2-X catch can | M017 Wheels
07-03-2018, 10:50 AM | #2 |
The "Thing"
Drives: 2016 Camaro 2ss,Whipple,R888R,A8 Join Date: Sep 2016
off idle they say to go WOT. Laynlo should be able to give you much more accurate information.
Helping Others
07-03-2018, 12:39 PM | #3 |
1. Burnout in 2nd
2. Get into either sport or track mode. 3. Be sure to override the suspension mode and put it into tour. 4. Double tap the traction control button to get it into competition/competitive mode. 5. Leave at an idle. 6. Let the computer shift. If you try to manually shift 1-2..you will most likely fail.
07-03-2018, 12:49 PM | #4 | |
Drives: 2016 2SS A8 Join Date: Feb 2016
16 Summit White 2SS-MRC-NPP-A8 :: PrayPorted IM - LT5 TB - Mishimoto Catch Can - RotorFab - E85 - TSP 2" LongTubes - Speed Engineering X/Mid Pipe
DIY Hpt Tune - DR - 1.75-60' - 7.47@95 - 11.56@120 with +2676DA |
07-03-2018, 12:50 PM | #5 |
Yeah..it's softer...helps weight transfer.
07-23-2018, 03:11 PM | #6 | |
Drives: 1SS, A8, MRC, NPP, Blade Spoiler Join Date: Jun 2010
Also, with stock tires, would you recommend lowering the rear tire pressure, and if so, what tire pressure would you recommend? Thanks for your help! |
07-23-2018, 04:49 PM | #7 |
Drives: A10 ZL1 Join Date: Mar 2018
I’m also curious if anyone has had luck with using the paddles on the A10. I’ve run in auto but I’ve been getting a 12.8.
07-23-2018, 08:46 PM | #8 | |
BAMF SS
And don't double tap the traction control button. Press and hold it for 5 seconds. That way it turns off all the nannies.
2016 1SS A8: FBO + Circle D + P1X + Meth + Tuned by Pray Performance
Stock Longblock 800 SAE rwhp. 9.4 @ 145 mph. |
07-23-2018, 09:23 PM | #9 |
Drives: 14 Silverado LTZ Z71, 16 Camaro SS Join Date: Nov 2009
You can 60 harder with a slight brake torque or a timed slight flash. Completely off idle works but I’ve got the lowest 60 brake torquing to about 1200
Dan have you actually tried 3rd and stock gears? Sounds good just wondering if it would have enough to break the tires loose effectively. Will the computer even let you start in 3rd? |
07-23-2018, 09:24 PM | #10 | |
07-23-2018, 10:10 PM | #11 | |
BAMF SS
In previous cars, I always got best results doing a burnout in 2nd gear. Gearing wise, our second gear is most transmissions 1st gear, and our 3rd is more like a second. I cant say I tried it with stock gearing...... I'm having waaaayyyy too much fun with these 3.73s. Lol
07-23-2018, 10:29 PM | #12 | |
I just been trying to avoid shifting during burnout after a tranny explosion I heard about. I’ll try only 2nd as well as 2nd to 3rd. The extra wheel speed of 3rd will be nice I agree it’s probably better than 2nd |
