Old 05-06-2018, 09:44 AM   #29
Chevy71
Chevy71's Avatar
Drives: 2016 2SS
Hi all, I'm sorry I have not been on in a long time. I still have not installed my light yet. I stopped looking for the VSS wire due to several things happening at home. Things are getting back to normal now so I will get back into this soon.
2016 2SS/Hyper Blue/M6/NPP/Navi
Forged pistons
Custom cut Brian Tooley Cam
SW long tube headers
3" stainless mid pipe - Secondary Cat delete - High flow cats
Port and polished heads-Double valve springs-platinum lifters & push rods
Cam phaser limiter - DOD delete
P1SC-1 Pro Charger 3.7 pulley
Stage II intercooler
667rwhp 577ft lbs
Chevy71 is offline   Reply With Quote
Old 05-06-2018, 09:45 AM   #30
Chevy71
Chevy71's Avatar
Drives: 2016 2SS
Originally Posted by hogwild87 View Post
I just installed my raptor last night and i couldn’t get it to work and i attached green wire to pin C on #1 coil blue wire with purple tracer and had ppr set to 8 cylinder mode. I even tried the 1/2 ppr and I believe it went into error mode
This is the same light I got. How did you tie your light in with the coil?
Forged pistons
667rwhp 577ft lbs
Old 08-15-2018, 10:38 PM   #31
chrest
chrest's Avatar
Drives: 2017 Camaro 2SS
Bump. Have mine all wired up except the tach input and vss. I bought this from chevy71. Any updates? Can’t find anything about it
2017 NGM 2SS NPP M6 MRC
Vortech SC, 2" TSP LT No Cats, Borla X, Eibach,
Hurst shifter
603hp/547tq
chrest is offline   Reply With Quote
Old 08-18-2018, 03:53 PM   #32
Fraxum
Fraxum's Avatar
I added an obd2 interface on my M6 in that build thread. But i heard the GMR pickup works and is a cleaner solution.
https://www.jegs.com/i/MSD/121/8918/...RoC9g4QAvD_BwE
Old 03-22-2021, 06:22 PM   #33
phaedrus
phaedrus's Avatar
Drives: 2018 Camaro ZL1 Convertible, M6
Has anyone got the GMR pickup to work?
I have tried all 4 wires on one cylinder’s coil and couldn’t get the GMR (MSD 8918) to work.
phaedrus is offline   Reply With Quote
Old 04-07-2021, 01:23 PM   #34
GirlyNFG
GirlyNFG's Avatar
Drives: 2016 Camaro SS M6 w/ NPP
Used to have a MSD shift light, hated it... Now I have this and love it...
I highly recommend one with a adjustable progressive setting.
Whipple 2.9, Custom New Era Performance cam,
E85, LT4 fuel system, Motec powered port injection, teeny tiny Nitrous Outlet system,
Stainless Works LTs, Centerforce Triad, GForce 9" with strange pro case 3.50 gears. Carlyle 15" conversion
28"x10.5" MT ET Drag 28"x4.5" M&H fronts
PB: 9.569 @ 151.05
GirlyNFG is offline   Reply With Quote
Old 04-15-2021, 06:57 PM   #35
lt4camaro
lt4camaro's Avatar
Drives: 2021 LT1 10 speed auto
Holley Sniper shift light
This unit plugs right in to the OBD2 diagnostic port and you can set the shift light to come on any rpm you want and can set each gear separately.
lt4camaro is offline   Reply With Quote
