Old 03-04-2024, 09:30 PM   #1
2004YZFR1
Drives: 2020 Chevrolet Camaro Coupe 2SS 1LE
Brembo LCF 600+?
Anyone try this Brembo LCF 600+ out yet? And if so how did you like it?
Did the fluid last for at least a few 2 day HPDE events for the year?
I've been running Castrol SRF for the last few years but wanted to try something different.
2004YZFR1 is offline   Reply With Quote
Old 03-05-2024, 09:33 AM   #2
dpevans
Drives: 2024 Riverside Blue 2SS 1LE
I have never had an issue with SRF and I doubt I would ever reach the boiling point only doing 20 min HPDE events. I have melted the rubber seals in the past and the SRF held up well and I do change it out yearly. The Brembo has a higher boiling point and is a little more expensive so if I was doing full day events with unlimited track time it might be worth it. Following to see how you like it.
dpevans is online now   Reply With Quote
Old 03-05-2024, 10:39 AM   #3
SCCAForums
SCCAForums's Avatar
Drives: Chevrolet Camaro, Ford Mustang
I run Endless 650... only fluid I've found as good or better than SRF. No experience with the Brembo fluid.
Endless gives a slightly firmer pedal feel when compared to SRF. Both phenomenal fluids.
Best regards,
Dave
2022 SS 1LE - Vivid Orange - SCCA CAM-C & Optima Ultimate Street Car GT
Katech, MSD, QA1, Hurst, Anderson Composites, ProParts USA Custom Suspension, MFR Engineering, Forgeline Wheels, G-Loc Brakes, Nine Lives Racing, MTX Audio, Penske Rapid Repair
SCCAForums is offline   Reply With Quote
Old 03-05-2024, 06:34 PM   #4
Vtor_ZL1
Who Needs to KNOW?
Vtor_ZL1's Avatar
Drives: 18 ZLE
Haven't tried that one yet.. have few more bottle of the BRF 600 or 660 variety to run through.
ing for grip.
http://www.motorsportsne.com/
Old 03-05-2024, 07:24 PM   #5
2004YZFR1
I like the SRF but I have heard the Brembo and Endless have a firmer brake pedal feel. The Brembo LCF has a few degrees less dry boiling point than the SRF. But the wet boiling point is significantly lower. I live in the desert so the brake fluid stays very dry out here.
Old 03-06-2024, 10:25 AM   #6
Blackmonba6Gen
BLUPRINT_1LE
Blackmonba6Gen's Avatar
Drives: 2022 Rapid Blue SS 1LE
I run the Brembo HTC 64T and I haven't had any issues with it so far. Only track I run so far was INDE out here in AZ. I considered the fluid a huge upgrade from MOTUL that I used to use and brake feel was a lot better.
2022 Camaro SS 1LE | PDR | Rapid Blue | Manual | Katech Built SS 1LE | Katech Build Sheet
IG: BLUPRINT_1LE
YT: BLUPRINT_1LE
Blackmonba6Gen is offline   Reply With Quote
