10-15-2020, 01:16 PM | #1 |
Drives: 2010 Camaro LT Join Date: Jul 2020
Need help identifying.
Is this normal? I can't find what this is for. Could it be why I'm getting a vacuum leak? It runs all the way to the back of the engine. |
10-15-2020, 01:28 PM | #2 |
Drives: 2010 Camaro 2SS Join Date: Jul 2020
Could be AC drain
10-15-2020, 01:40 PM | #3 |
Okay that makes sense I guess. But is it suppose to be exposed like that?
10-15-2020, 01:42 PM | #4 |
Evil Genius of Chevrolet
Drives: 2017 Z06, 2019 XTS, 2013 SS Join Date: Feb 2017
That's the Mustang sniffer to help you avoid getting taken out by a sideways traveling model.
GPI SS2 VVT cam, ECS Novi 1500 supercharger, Corsa Extreme, Detroit Speed and BMR suspension, Circle D triple disc, Melling oil pump, LS2 chain tensioner, ATI 10% UD, DSX E85 kit, High Energy coils, BTR springs, LS2 Lifter trays, Titanium retainers, hardened push rods, FIC 1000 injectors, ZL1 pump, Mighty Mouse catch can, AEM gauges, Tial BOV, Richmond 3.91 gears, Custom gauge bezels, Speed Engineering headers, Stainless Works HF cats, DSX Aux pump, 710rwhp on E85.
10-15-2020, 01:43 PM | #5 |
Sporting Foole
Drives: 2010 Camaro SS Join Date: Sep 2019
10-15-2020, 01:45 PM | #6 |
Is it part of the EVAP line (running from fuel tank to EVAP solenoid on intake manifold)?
10-15-2020, 02:19 PM | #7 |
Drives: 2015 Z/22 Join Date: Aug 2015
Overkill/Self Tuned; Mace Camshafts; K&N Typhoon Cold Air Intake; Ported 80mm Throttle Body/Intake Manifolds/Manifold Spacer; Solo Performance High-Flow Cats, Cat-back Exhaust; Vitesse Motorsports Throttle Controller; Elite Engineering E2 Catch Can; BC Racing BR Coilovers; JPSS Delrin Radius Rod Bushing Inserts, Sway Bars; Pegasus Aluminum Rear Cradle Bushings, Camber/Caster Plates; Z/28 Toe Links, Trailing Arms, Upper Control Arm Bushings, Rear Shock Mounts
10-15-2020, 02:34 PM | #8 |
^^^^ this, it is the vent tube for the auto transmission cars..
10-15-2020, 04:53 PM | #9 | |
Yeah it's on the same area. Thanks for the info, I've never actually noticed it untill now. Bought the maro a year ago..so yeah.. |
10-15-2020, 08:04 PM | #10 |
No prob - I've had mine for 6.5 years and never knew it was there... and I've been under there dozens of times!
