04-07-2019, 11:54 AM | #1 |
Best mod for <$400
As the title reads I’m looking for the best mod for under $400. I currently have window tint, diode dynamic smoked side markers, and the OEM front fascia extension. I want to keep my warranty as well!
04-07-2019, 01:06 PM | #2 |
Drives: 2017 Camaro 1ss Join Date: Mar 2019
From what I've gathered so far is an axle back exhaust and cai are the only performance mods that dont void warranty.
04-07-2019, 01:07 PM | #3 |
Drives: SS-6-SPD Join Date: Jan 2017
GM Dark Tails
Side Skirts Rear Diffuser Intake Spoiler Lowering Springs |
04-07-2019, 01:27 PM | #4 | |
Drives: 2017 1SS 1LE...makes me go YeeeHaw! Join Date: Mar 2012
Save your money, and then purchase mods that will give you better performance for your bucks, and you'll be able to spend more than $400 by that time. Maybe a catch can for now, but even then the dealer can say it caused something....of course they would have to prove it, and the CC is actually better for the car since it is only a DI and not a multi DI. You don't want to purchase mods for the sake of mods, but you should want to purchase mods for increased performance, then again some do it for looks as well...I'm just not a show person, so a good CAI will most likely cost over $400, then again I haven't really looked into too many mods just yet. I'm still considering the oil brand/type.
The Thrill isn't around the corner, the Thrill is the corner!
So don't hesitate, just brake late! |
04-07-2019, 03:05 PM | #5 |
Track day
It's been fun, done with GM.
2018 Camaro ZL1 (SOLD) - Blown Airbags 2017 Camaro SS F1FTY Member Journal (SOLD) - Bad Motor |
04-07-2019, 05:59 PM | #6 |
Drives: 23 2SS 1LE Join Date: Feb 2019
People are talking about a CAI and I've been seeing some comparisons and anything all that cheap seems to have some drawbacks and even the expensive ones don't give that much of a performance gain. Unless your taking the car to the track and need every possible 0.1 off your time. But a simple drop in "Green Filter" into the stock air box, you can get a good bit. And it's only $50
Instagram: RideWithDanger
Radiant Red 23' 2SS 1LE 1100: 11/14/22 | BUILT: 3/16/23 2000: 2/17/23 | 4200: 5/8/23 3000: 2/27/23 | 5000/6000: 5/15/23 Black on black 2019 3LT RS Camaro. 1100: 3/7/19 | 4200: 4/15/19 3100: 3/15/19 | 4800: 4/23/19 3400: 3/22/19 | 5000: 4/25/19 Built: 4/8/19 | Home: 4/26/19 |
04-07-2019, 06:19 PM | #7 |
Drives: 2018 1SS Join Date: Dec 2018
Ported Throttle Body is one of the more impactful mods for drivability, and as long as you keep your original, it is a "traceless" mod. Takes about 15 minutes to swap it out, so one of the easiest you'll do as well.
2018 Red Hot 1SS, GM lowering kit & 1LE Sway bar kit, ZL1 1LE solid rear cradle bushings, BMR sway bar end links, GM CAI w/tune, Pray ported IM, Mamo ported TB, VS Forged VS07 rims 20x11 & 20x10 w/ Michelin PS4S
04-07-2019, 06:20 PM | #8 |
Cold Air Inductions or Roto-fab make a good CAI for the SS which is around $400. I had a Cold Air Inductions system on my 2016 SS and it made a noticeable difference to me in the sound and performance and I didn’t consider it a waste of money. If you want a louder exhaust then an axle back would be a good purchase too. Really just depends on what you are wanting to do and how much money you want to spend but I would say that either a CAI or exhaust might be the place to start with mods!
04-07-2019, 08:56 PM | #9 |
SABIO
This.
Go out and enjoy your car. It faster than you think it is.
04-07-2019, 10:54 PM | #10 |
Drives: 2019 2LT 2.0T M6 Riverside Blue Join Date: Jan 2018
"mod" is a pretty large category...what do you mean by "best"? Are you looking for power gains? Cosmetics? Suspension/chassis improvement?
04-08-2019, 05:38 AM | #11 |
04-08-2019, 05:43 AM | #12 |
04-08-2019, 07:52 AM | #13 |
Drives: 2018 SS 1LE Join Date: Jun 2018
04-08-2019, 07:56 AM | #14 |
This is also not true, It's traceable. When you put a socket (unless its rubber padded) on a Nut or bolt and turn it leaves a wear impression into it. GM engineer's know to look for these impressions on bolts when inspecting a blown motor. You can't hide anything these days. You will also see paint marks on some bolts they look to see if the line has been broken.
