Old 01-31-2019, 09:35 PM   #29
18ss376
Drives: Camaro
Originally Posted by JonD View Post
Ok... wasn’t really talking powerglide with my reference, lol
I’m more talking about the 95% of people who are full bolt on and at different power level under 500whp & those over 500hp.
I see everyone running 28” but have heard pretty good debates on the reason a 26” could be quicker keeping the car in the power. I’ll find out first hand as I went 26” and have a 28” to try from a buddy as well
I know...lol
But your right about the 28 vs 26 tires, JMO I think the 26 would be faster on a stock to mild build. I could see the LT4 power level & higher benefit from a 28" tire.
18ss376 is offline   Reply With Quote
Old 02-02-2019, 12:50 AM   #30
JonD
JonD's Avatar
Drives: 2018 SS 1LE
Ready to test
🌽 Sauced, 2018 SS 1LE - 123mph @ 5,000 DA
ARH 2”x3” FULL System, Pray Ported MSD Intake Manifold, Pray Ported GM 95mm TB, RotoFab CAI, DsX e85 Kit, MightyMouse Catch Can, NicD Tune
https://instagram.com/corn_sauced?ut...d=o0ako89uurwl
JonD is offline   Reply With Quote
Old 02-03-2019, 04:34 PM   #31
JonDaddy82
JonDaddy82's Avatar
Drives: 2018 ZL1 Coupe NFG M6
Nice! What's the setup?
1989 Forumla 350 WS6 <- High School
2000 Trans Am Firehawk <- After High School
2017 Colorado Z71 <- Daily
2018 ZL1 M6 <- Not Daily
JonDaddy82 is offline   Reply With Quote
Old 02-03-2019, 04:39 PM   #32
JonD
JonD's Avatar
Drives: 2018 SS 1LE
Thanks! Here’s my set-up
*DragStar 17x9.5 #92-795252G
*Mickey Thompson ET Street R’s P275/40-17
*DragStar - 18x5 #92-850245G
*M&H - 185/50R18
Old 02-03-2019, 08:22 PM   #33
18ss376
Drives: Camaro
I just can't get used to the wheel height difference, just doesn't look good to me.
I'm old so I like same size wheels & will never own a set of black wheels...lol
Old 02-03-2019, 09:14 PM   #34
JonD
JonD's Avatar
Drives: 2018 SS 1LE
Looks fresh as hell to me & I’ll never own a set of Chrome wheels.
It’s good they make options for everyone
Old 02-04-2019, 08:17 AM   #35
18ss376
Drives: Camaro
Yes, it's good they make any color wheel you want today. Just not for me.
You do know it is WAY less expensive to make black wheels vs a beautiful billet CNC polished aluminum wheel. The industry is making a killing off everyone that buys or owns black wheels. Paint & powder coating is super cheap. I'll be dead before I put anything but polished aluminum wheels on any car I own. Okay I'm off my soap box now, carry on.
Old 02-04-2019, 09:14 AM   #36
JonD
JonD's Avatar
Drives: 2018 SS 1LE
I Not a fan of the black wheels either, that’s why mine are gunmetal gray.
The price of the fancy Welds is just ridiculous unless you’re pushing big HP & actually need beadlocks or just have the extra $ to spend.
Old 02-04-2019, 11:43 AM   #37
G2K
@Blackmamba_1LE
G2K's Avatar
Drives: 2017 1LE
Only reason why I run 28" is because i dont want to give in that much to drag racing and want to stay with my 20's up front... also an alignment is needed everytime you touch the front (height and width) dont see it viable for me on something i do every now and then... if i had skinnes, then i would also be on 26"
Also 28" look so much better on these cars
any reason why you went in such a narrow setup? 275/40/17 i/o the usual 315/35/17??? I would think the wider 315 would grab better.
OG: Pray Perf FBO ET:11.5 @119 THEN:LT4 SC, E85 + Meth :10.6 @135 NOW: H/C Whipple 416ci
G2K is offline   Reply With Quote
Old 02-04-2019, 11:59 AM   #38
JonD
JonD's Avatar
Drives: 2018 SS 1LE
I picked the setup based on the tires combo that will hook without going overboard or rubbing & based on power level/gearing & I want to run full Drag Pack vs. trying to keep the 20” fronts on. I’m not a fan of the possible 100mph sway if it happens from running the softer rear
My idea is that at anything Sub 600whp on the 6M I’d be hurting my times by running a larger tire and kicking myself out of the target RPM range.
Also I absolutely wanted to keep the front/rears matching in size and this is about as perfect as it gets when you use the tire calculator.
On the street it hooks pretty well so imagine it on a prepared track.
Too bad we’re not closer as I’d love to see some of the 28” tire guys try this set up to see if it changes their ET/MPH for the better. I agree the 28” fills the space up better BUT after having this set up I’m in love with the look keeping the car low to the ground
Old 02-05-2019, 08:25 AM   #39
18ss376
Drives: Camaro
*M&H - 185/50R18
I do like the way your car sits 2" lower to the ground with your new set-up.
Old 02-05-2019, 12:51 PM   #40
laynlo15
laynlo15's Avatar
Drives: 2022 Lt1 A10
You ask so I think the tires just look to short. I like them close to the fender well or tucked. Mine tuck when I launch my car and that shows great weight transfer. Hope your hooks good. You might consider lowering it to tighten it up.
(18ss376 you were on that 2 step a long time. They shake and break stuff all the time.)
Old 02-05-2019, 01:52 PM   #41
JonD
JonD's Avatar
Drives: 2018 SS 1LE
I do think it’s a perfect combo so these next few track days will give me data
Ehhhh I think it looks great and I’m also only concerned with function at my HP levels vs. a fat tire filling up the well. I leave it in Touring mode to keep it as soft as possible being manual so I don’t think lowering it is for me
Time will tell when I run some times and see where I am with 60 foot & a few other things when crossing the 1320
Old 02-05-2019, 02:03 PM   #42
G2K
@Blackmamba_1LE
G2K's Avatar
Drives: 2017 1LE
Can't wait man finally some data that I can compare myself with...
