Old 03-29-2018, 05:09 PM   #1
RealQuick
Drives: 2010 Camaro 2SS M6 - Intake/Exhaust
Turbo guys, which oil pump you got?
New setup is a 416ci with low mount twins (with scavenge pump). Trying to decide between high volume or high pressure.
RealQuick is offline   Reply With Quote
Old 03-29-2018, 05:33 PM   #2
blake-b
blake-b's Avatar
Drives: 2009 ZR1
LME put a Melling 10295 (high pressure, not high volume) in mine. They knew it was going to be a twin turbo application. No issues at all and it runs well.
Old 03-29-2018, 05:39 PM   #3
Unavowed
Unavowed's Avatar
Drives: Twin turbo G8 GXP
High volume here.
Unavowed is offline   Reply With Quote
Old 03-29-2018, 06:07 PM   #4
0331Marine
0331Marine's Avatar
Drives: 2012 SS/RS MN6
Volume
0331Marine is offline   Reply With Quote
Old 03-31-2018, 05:30 PM   #5
stevieturbo
Drives: it changes
Pressure will be largely dictated by the relief spring and bearing clearances....and of course pump volume too.
Mine must be loose as feck though, LS2 block with oil squirters and a 296, oil pressure was never as high as I'd like, although it was always consistent.
So I rebuilt a couple of years ago and threw in a Melling 10355 DOD pump...I figured I'll throw some oil at it to get the pressure up !!
Didnt make a damn bit of difference lol
stevieturbo is offline   Reply With Quote
Old 04-02-2018, 10:26 AM   #6
hillshooter
Drives: 2015 Camaro SS commemorative
Watch the latest engine masters, they tested oil amounts and you will see why it didn't make a difference.
2015 Camaro SS, LS3 Stroker, PRC heads,CUSTOM CAM. AGP 68/68 with custom Hot and Cold side. Fore triple pumps, Holley terminator X. BMR drag suspension with carlyle brake kit. 15" ET drags and 17" skinnies. ZL1 3.73 gears , aluminum driveshaft. TH400 with circle D converter.
hillshooter is offline   Reply With Quote
Old 04-02-2018, 06:23 PM   #7
JMI
JMI's Avatar
Drives: Red Jewel Camaro SS
Hi Volume with the regular pressure spring that I was suggested.
BTR LSX388,AGP Twin Turbo.6L90,GM 9.9" Diff.Fore Innovations Level 4 fuel system.Great fuel economy !!!! 1xxx RWHP
JMI is offline   Reply With Quote
Old 04-05-2018, 09:03 AM   #8
Slowhawk
Drives: 1999 Trans Am
I use stock ported gm on all builds, you should plug the oil return in the oil pan.
Slowhawk is offline   Reply With Quote
Old 04-09-2018, 05:41 PM   #9
SSE 4 2SS
Boosted Moderator
SSE 4 2SS's Avatar
Drives: Bone Stock LS3
Send a message via AIM to SSE 4 2SS Send a message via Yahoo to SSE 4 2SS
This isn't the exact model, but it's close...
If the car feels like it is on rails, you are probably driving too slow. -Ross Bentley
Horsepower is how fast you hit the wall.
Torque is how far you take the wall with you.
“If everything seems under control, you're just not going fast enough.” Mario Andretti
If you can turn, you ain't going fast enough...
SSE 4 2SS is offline   Reply With Quote
