02-15-2018, 03:27 PM | #15 |
Served USN - Atomic Chimp
Drives: 13 Camaro LSX434 TT M6, 21 ZLE A10 Join Date: Jul 2012
M/T ET Street R P305/45R18 - yes, they are 29" tall
In excess of 1,000WHP LSX434 | AGP 65/65 TT | BTR Equalizer Intake | Trickflow 245cc cathedral | BTR custom cam | Cortex EBC | n2mb WOT | ID-1700x | Brisk GR12S | RPM Lv 7 TR6060 | AGP's Triple 525LPH Fore Fuel | Monster LT1-S Triple | 4.11 DSS Proform 9", CF driveshaft, 1400hp axles | Hurst Line Lock | MGW Retro Short Throw w/old skool Hurst T-handle | ADM solid subframe mounts | Prothane Motor Mounts | Revshift Poly Trans insert | Moreno camber/caster plates |
02-15-2018, 04:36 PM | #16 |
Drives: 2010 2SS LS3, 2013 duramax Join Date: Nov 2012
Do you already have the ls3 block or are you starting from scratch?
ECS Ysi-B, cam, Tsp 2" longtubes, Squash dual pumps, Id1300s, meth, 4L80e, FTI 3600, ZL1 3.73 diff, BMR suspension, 15" conversion, weld rts mt 275 et street R. 9.6@147mph
02-15-2018, 05:38 PM | #17 |
Drives: 2010 Camaro 2SS M6 - Intake/Exhaust Join Date: Sep 2014
Already on order. I am gonna give it a go. I appreciate the input though!
02-15-2018, 07:44 PM | #18 | |
700RWHP-650TQ
Drives: 2011 Forged LS3 Supercharged/Cammed Join Date: Aug 2010
Dez Racing doing the build?
View Build HERE>>>>>MY 2011 2SS/RS JOURNAL |
02-15-2018, 08:28 PM | #19 |
02-16-2018, 12:59 AM | #20 |
Drives: 2010 SS Join Date: Jun 2015
Have fun. Sacrificing reliability for 11 horsepower.. Just wanna feel cool to say "I have a 427"
02-16-2018, 01:51 AM | #21 |
I can call TSP tomorrow and see what they have for crank options less than 4.1” stroke. I don’t want stock stroke as I feel like it will be too lazy for twins and a M6. I am looking for a decent bump in cubes.
Also, next time you want to throw a zinger in there, proof read first. |
02-16-2018, 07:18 AM | #22 |
Drives: 2014 SS 1LE Join Date: Apr 2014
TSP even recommends if you are going to be over a certain boost level then to go with a 4.00 in stroke. Also might as well hit that fuel system while you are at it. You are going to be immediately limited with that zl1 pump as soon as it hits the dyno. Why have big 62's and not feed them?
02-16-2018, 08:44 AM | #23 | |
Funds will be the limiting factor. I’d rather get the setup on the road and log some miles. I only put on 500-1000 miles a year, so for the first season I am gonna run the current fuel system on low boost. On my previous turbo setup, I only hit ~62% inj DC at 817rwhp/758rwtq due to the meth inj. Obviously the bigger motor setup will require more fueling, but I suspect I can start with low boost and log data. I do agree I will need a more robust fuel system to push the new setup. |
02-16-2018, 09:40 AM | #24 | |
Drives: Black 2SS RS w/White Stripes Join Date: Mar 2011
I am leaning towards a re-sleeved block at the moment. 416 with Dart billet crank.
2010 2SS/RS "ChriSStine":
Pat G Custom Turbo CamMotion Camshaft | AGP TT BB Garrett 62/65's | AGP/Fore Triple Pumps | ID1700X Injectors | Alky Control Twin Nozzle Meth | Custom 3" Exhaust | 3.27 gear set w/ Tru Trac | McLeod Twin RXT | Barton Short Throw Shifter | 6th Gen ZL1 Wheels | BMR 1.4" drop springs | Pfadt rear trailing arms & tie rods | Installed by Me & Tuned by Pat G |
02-16-2018, 10:09 AM | #25 |
I’ll post back in here after I talk to them. 4.0” stroke will get me to 416ci, so if they allow me to switch it out, then I’ll go with that.
02-16-2018, 10:55 AM | #26 |
I'm eyeing that Concept Performance LSR 6-bolt aluminum block... Looks pretty stout. Was thinking 427, because it sounds cool, but having a hard time nailing down heads. So far, the Brodix BR7-3 looks pretty flowy.
02-16-2018, 10:59 AM | #27 |
Athena fire ring gaskets and 1/2" studs will hold more boost than most people here will make anyways.
02-16-2018, 12:36 PM | #28 |
Drives: 2010 Camaro (M6) 1000+ HP SBE Join Date: Jun 2011
Go for it Quick! Should be a monster!
Now I will show my ignorance to the group . . . If you go 427 LSX is high boost still an issue?
F-1X, Cog Drive, ATI Super Pulley/Sprag ~ 19 psi
Blower Cam Brodix BP BR 3 Heads Kooks LT Headers and full 3" exhaust Fore Triple Pump Fuel System with ID 1700X Injectors - E85 conversion DSS 9” Conversion (1400 hp axles, driveshaft, pumpkin) & Strange 3.70 gears McLeod RXT Twin HD Clutch & Upgraded Slave RPM Level VII TR6060 BMR Drag Suspension Package w/Strange shocks Carlyle 15" and M/T ET Street R radials 10.1 @ 143 mph 1/4 mile |
