TireRack
Old 11-04-2017, 10:37 AM   #15
mrimpala02
Drives: Black 2SS RS w/White Stripes
Originally Posted by RealQuick View Post
Thanks!!! Leaving in 5 min. Gonna tune both my camaro and gto.
Sounds like a badass day!!
Good luck!
2010 2SS/RS "ChriSStine":
Pat G Custom Turbo CamMotion Camshaft | AGP TT BB Garrett 62/65's | AGP/Fore Triple Pumps | ID1700X Injectors | Alky Control Twin Nozzle Meth | Custom 3" Exhaust | 3.27 gear set w/ Tru Trac | McLeod Twin RXT | Barton Short Throw Shifter | 6th Gen ZL1 Wheels | BMR 1.4" drop springs | Pfadt rear trailing arms & tie rods |
Installed by Me & Tuned by Pat G
mrimpala02 is offline   Reply With Quote
Old 11-04-2017, 01:47 PM   #16
RealQuick
Drives: 2010 Camaro 2SS M6 - Intake/Exhaust
Originally Posted by BiggFoot View Post
Good luck today . . . Please keep us posted!!
We'll, interesting day at the dyno... brought two cars down (camaro and my cammed gto). The gto came back on a flatbed. Sounds like something let go in the bottom end on the ride down under easy cruising.
the camaro was having some issues with boost. With the controller off and running gate only 8psi)... it would ramp up to 8psi quick and then continue to creep to 15-16psi. MAF readings were all over the place (like last time when I had compromised plug wires).
peak tq was just past 8psi and peak power was at 15-16psi.
made only 818rwhp/692rwtq.
just for reference, when it held 16psi before (but with clutch slip up top) it made 817rwhp/758rwtq. The 817rwhp was at ~5600rpm last time, this time it made peak power at 6500rpm, just boost was all over the place. My boost gauge in car was jumping everywhere from 8 to 0 then to 10 then to 16.
looks like I'll have to either relocate the coils to address the plug wire issues or switch to twins down low to keep the wires alive.
Timing finished at 15 degrees... 17 degrees netted 3hp, so I put it back to 15.
i have the winter now to strategize on keeping the ignition wires alive.
RealQuick is offline   Reply With Quote
Old 11-04-2017, 09:43 PM   #17
fif_gen_powa
fif_gen_powa's Avatar
Drives: 2013 Camaro SS Turbo
What's wrong with the wires, getting burned? I wrapped my wires pretty thick with the exhaust header wrap as it was burning through the thin plug wire sleeves and it's been good ever since
388ci 91/104 Turbo TH400
8.3@164
https://instagram.com/turbo_ls3/
fif_gen_powa is offline   Reply With Quote
Old 11-04-2017, 09:44 PM   #18
BiggFoot
BiggFoot's Avatar
Drives: 2010 Camaro (M6) 1000+ HP SBE
Dang bro . . . I know this has not been the day you were expecting. You strike me as a guy that will stay on it until you get it figured out and corrected. Keep your chin up, seek a lot of advice, and in the end make your decision and go with it. The sun will shine tomorrow.
F-1X, Cog Drive, ATI Super Pulley/Sprag ~ 19 psi
Blower Cam
Brodix BP BR 3 Heads
Kooks LT Headers and full 3" exhaust
Fore Triple Pump Fuel System with ID 1700X Injectors - E85 conversion
DSS 9” Conversion (1400 hp axles, driveshaft, pumpkin) & Strange 3.70 gears
McLeod RXT Twin HD Clutch & Upgraded Slave
RPM Level VII
TR6060
BMR Drag Suspension Package w/Strange shocks
Carlyle 15" and M/T ET Street R radials
10.1 @ 143 mph 1/4 mile
BiggFoot is offline   Reply With Quote
Old 11-04-2017, 10:17 PM   #19
RealQuick
They have always had DEI sleeves, but just themes underwood kooks them. Not sure the wires are toast... but definitely some ignition issue going on. The boost gauge was going wacky too during the runs, jumping all over.
Old 11-04-2017, 10:18 PM   #20
RealQuick
Thanks. Yeah, disappointed, but it stayed together. More worried about the gto now... something sounds awful from the bottom end.
Old 11-09-2017, 08:29 PM   #21
Dirtdog
Pro Hide n Seek Player
Dirtdog's Avatar
Drives: 2010 SS LS3/LSA 620whp/630tq
Send a message via AIM to Dirtdog
i had wires getting cooked. I got some Accel ignition plug wires and they have a ceramic cover. no more cooked wire. only like 100 bucks and look nice too
620whp/630wtq. ADM LSA Conversion, E85, PFADT Tri-Y Headers into Borla S, PFADT Swaybars, Springs, Links, 20x10 20x11 Forgestar F14s, Lots of AAC
Dirtdog is offline   Reply With Quote
Old 11-09-2017, 08:47 PM   #22
RealQuick
I tried them, but the boot is too long and they run into the manifolds
Old 11-09-2017, 08:53 PM   #23
fif_gen_powa
I thought about relocating coils and making custom longer wires to keep them away from the manifolds but mine have held up so never got around to it
8.3@164
Old 11-09-2017, 09:11 PM   #24
RealQuick
Relocating the coils is probably a winter project for me.
Old 12-03-2017, 11:24 PM   #25
RealQuick
We'll, GTO has a toasted rod bearing, so I am taking the LS3 out of the camaro and putting it in the gto while it is still a good factory shortblock. The GTo ported LS6 heads will go on it and I need to spec out a 4X cam.
So... started tearing down the camaro (first time touching the car since the dyno). Upon tear down I see that I had 5 burnt plug wires out of 8! No wonder the dyno was funky! Still made s lazy 818rwhp with bad wires though! Encouraging. Probably will do a coil relocation over the winter, along with a forged shortblock. I just wanted to update this thread with my findings.
Old 12-04-2017, 09:54 AM   #26
bayarea408
bayarea408's Avatar
Drives: T
Thank to this guy, my wires are wrapped thick and have held up great as well.
I use PCM of NC wires, if you are running a Huron kit these wires fit really good for the manifold provided.
bayarea408 is offline   Reply With Quote
Old 12-04-2017, 05:27 PM   #27
RealQuick
I used the same wires, the lasted ~50 miles before one cracked.
Don't know why, but it's happening. Once I get it sorted out, it will be a beast.
Old 12-05-2017, 08:36 AM   #28
RealQuick
Pic attached, all in the same spot on the wires, these were bent up at 90 degrees. I think part of the problem is the header studs dig into the heat sleeves in the same area, may be contributing.
