Roto-Fab
Old 10-23-2017, 11:19 AM   #1
RealQuick
Drives: 2010 Camaro 2SS M6 - Intake/Exhaust
What is going on with my TPS?
Last time I drove my 2010 Camaro SS was in August (single turbo, stock bottom, NW102 TB).
I tried to drive it last weekend and I had some issues which I think was due to a low voltage from battery.
Put on a battery charger and fired it up this weekend. Idle sounded good and a quick WOT pull on low boost on the street felt great.
When looking at the TPS though... it jumps all over the place. One pic is at idle and one is during the run. TPS is purple line at the top.
The NW102 has ~500 miles on it, bought it brand new. Function great previously, not sure it is the problem.
RealQuick is offline   Reply With Quote
Old 10-23-2017, 05:17 PM   #2
RealQuick
So I hooked up my stock TB and got the same wavy TPS... so it isn't the TPS
unhooked completely the tps is wavy between 60-100%
maybe a short in the harness?
Old 10-25-2017, 07:58 AM   #3
RealQuick
Checked all my wiring harness on the pass side, nothing looks burnt (I did a nice job of heat protection).
With engine off (key on) TPS with pedal to the floor only registers 91% and it is wavy still (does it with two different TB's). I ordered a new gas pedal/sensor assembly for $59 from local GM dealership. We'll see if it works.
Old 10-26-2017, 04:31 PM   #4
stevieturbo
Drives: it changes
On a DBW car, the pedal will have two tracks and the throttle unit at the engine will have 2 tracks.
So what you're seeing on that log has less meaning as it will be some sort of amalgamation of the raw values.
Although strange it's doing that, and no fault codes being thrown, as these tend to be quite sensitive.
But you need to see the raw data from all 4 inputs to see if there are any anomalies.
stevieturbo is offline   Reply With Quote
Old 10-26-2017, 10:13 PM   #5
RealQuick
Steve,
I Found the problem!
when I set my scanner up, I used the TPS (SAE) PID.
​​​​​​​i switched to scanning just the TPS and all is smooth and pedal all the way down reads 99.6!
