Old 06-15-2017, 09:50 AM   #15
RealQuick
Drives: 2010 Camaro 2SS M6 - Intake/Exhaust
Attached below are the hptuners log (and also the exported excel version), and I attached some graphs from the excel file.
If you look at rpm vs time, you can see the rpm's fluctuating (I assume spark blow out or clutch slip).
If you look at the MAF and A/F pic... it would appear as if the clutch is slipping causing loading/unloading of the motor which causes the MAF to be whacky which translates into A/F being whacky.
Thoughts?
RealQuick is offline   Reply With Quote
Old 06-15-2017, 09:55 AM   #16
RealQuick
Here are two screen shots of another run on the dyno where slip was much more visible. I circled rpm and mph in each pic.
Old 06-15-2017, 10:02 AM   #17
BiggFoot
BiggFoot's Avatar
Drives: 2010 Camaro (M6) 1000+ HP SBE
Soooo what clutch do you have? I realize the clutch is not your main problem but dang that graph is hard to read (looks like a pick-up-stick pile).
F-1X, Cog Drive, ATI Super Pulley/Sprag ~ 19 psi
Blower Cam
Brodix BP BR 3 Heads
Kooks LT Headers and full 3" exhaust
Fore Triple Pump Fuel System with ID 1700X Injectors - E85 conversion
DSS 9” Conversion (1400 hp axles, driveshaft, pumpkin) & Strange 3.70 gears
McLeod RXT Twin HD Clutch & Upgraded Slave
RPM Level VII
TR6060
BMR Drag Suspension Package w/Strange shocks
Carlyle 15" and M/T ET Street R radials
10.1 @ 143 mph 1/4 mile
BiggFoot is offline   Reply With Quote
Old 06-15-2017, 10:05 AM   #18
RealQuick
Street Slayer Billet Twin. I emailed Thomas at Hendrix and he said I may need to put more heat into it for further break in.
Old 06-15-2017, 10:30 AM   #19
BiggFoot
BiggFoot's Avatar
That should be a good clutch, at least the decal is cool!!
Blower Cam
RPM Level VII
TR6060
Old 06-16-2017, 06:24 AM   #20
Slowhawk
Drives: 1999 Trans Am
You really just need to have the clutch work. A slipping clutch can screw up all power readings,tuning.
Slowhawk is offline   Reply With Quote
Old 06-16-2017, 06:50 AM   #21
RealQuick
I agree. Thanks Don.
Old 06-21-2017, 08:57 PM   #22
RealQuick
Pulled the plug wires and found 4 out of the 8 were cracked. So with new plugs/wires and if clutch will hold, I should be able to improve on the 817rwhp.
Old 07-06-2017, 09:49 PM   #23
RealQuick
Some updates. I replaced four cracked plug wires and the BR7EF's @ .028" with new wires and Iridium NGK #8's @ .025.
A few things I noticed:
1) Speed vs time is now ulta smooth (at 10psi anyway)
2) MAF readings are now smooth (vs choppy before)
3) I am about 1.5 AFR leaner now han when on the dyno
Pic 1 is speed vs time from the 817rwhp dyno pull (16psi)
Pic 2 is speed vs time 10# street pull after plugs wires
Pic 3 is MAF vs time from the 817rwhp dyno pull (16psi)
Pic 4 is MAF vs time 10# street pull after plug and wires
