Old 05-23-2017, 11:27 AM   #1
RealQuick
Drives: 2010 Camaro 2SS M6 - Intake/Exhaust
Dyno confirmed for 6/3 - Results are in on the Huron Setup
Getting ready to hit the dyno again (4th time with turbo setup)... made some modifications over the winter:
removed wastegate dump from downpipe to atmosphere
removed airfilter in lieu of a screen
added twin cutouts on my 2.5" dual exhaust just after where the single 3" DP splits
Aluminum DS
Street Slayer Twin Disc
Here is a rundown of the car from previous runs:
2010 Camaro SS M6
Stock bottom end
AI 280cc Heads
Vengeance racing turbo cam (235/231 .6xx/.6xx 115lsa)
Ported LS3 Intake
NW102 TB
1000CC Injectors/ZL1 pump/ADM FPCM
Huron Speed single turbo kit with Precision 7675CEA
Alky Control w/100% meth
SLP under drive pulley
No cats
borla ATAK 2.5" exhaust
Tune via hptuners (me tuning)
going to be dialing in for 3 settings:
Wastegate - 8psi
Setting A - 16psi
Setting B - 12psi
Numbers will be on a dynojet and running 93 + 100% meth
I previously made 762rwtq @ 16psi, then boost fell to 703rwhp @ 13psi. Boost on that run was 16psi @4500, 13psi@5400rpm, 11psi@6000rpm. Hopefully my mods over the winter eliminates the boost fall off issue so I can make a clean run @16psi.
RealQuick is offline   Reply With Quote
Old 05-23-2017, 11:46 AM   #2
BiggFoot
BiggFoot's Avatar
Drives: 2010 Camaro (M6) 1000+ HP SBE
You and I both have stock bottom ends so we are pushing the envelope. Here is hoping you will see 800 HP
F-1X, Cog Drive, ATI Super Pulley/Sprag ~ 19 psi
Blower Cam
Brodix BP BR 3 Heads
Kooks LT Headers and full 3" exhaust
Fore Triple Pump Fuel System with ID 1700X Injectors - E85 conversion
DSS 9” Conversion (1400 hp axles, driveshaft, pumpkin) & Strange 3.70 gears
McLeod RXT Twin HD Clutch & Upgraded Slave
RPM Level VII
TR6060
BMR Drag Suspension Package w/Strange shocks
Carlyle 15" and M/T ET Street R radials
10.1 @ 143 mph 1/4 mile
BiggFoot is offline   Reply With Quote
Old 05-23-2017, 01:02 PM   #3
AGP Turbo
Drives: All things Turbocharged
With all those exhaust flow improvements, that should make a major difference. That's an 1000+whp turbo when everything else not choking it off.
AGP Turbo is offline   Reply With Quote
Old 05-23-2017, 01:15 PM   #4
fif_gen_powa
fif_gen_powa's Avatar
Drives: 2013 Camaro SS Turbo
What did you do with the wastegate dump?
Should make 800 if you got the octane w/enough meth. I think the 3" downpipe is maxed much more than that
388ci 91/104 Turbo TH400
8.3@164
https://instagram.com/turbo_ls3/
fif_gen_powa is offline   Reply With Quote
Old 05-23-2017, 02:05 PM   #5
jeff657756
Drives: 2014 SS 1LE
Still with ZL1 pump?
jeff657756 is offline   Reply With Quote
Old 05-23-2017, 02:11 PM   #6
RealQuick
I hope so. I think the cubes are too big verse the 3" DP. I think @ 20-22psi, this turbo would be done... probably in 875-900rwhp range.
Old 05-23-2017, 02:46 PM   #7
hillshooter
Drives: 2015 Camaro SS commemorative
ZL1 pump sounds maxxed.
hillshooter is offline   Reply With Quote
Old 05-23-2017, 07:00 PM   #8
RealQuick
Based off of previous logs ands use of meth injection, I don't think it will max out until around 850rwhp. I also have 1000cc injectors.
Previously I didn't log inj duty cycle on the dyno, but my street pulls after the dyno on 12psi showed under 60% duty cycle (if I recall correctly I want to say it was actually like 48% duty cycle). Big injectors and meth injection (supplemental fuel delivery) will allow that pump to go far beyond the normal limits.
Most people on here max these out around 700rwhp on gasoline only and 850cc injectors.
Old 05-24-2017, 11:05 AM   #9
RealQuick
Wastegate is flipped 180 degrees and faces front. I made a 90 degree pipe (like 36" long) to run it straight down to the ground.
Old 05-24-2017, 10:49 PM   #10
RealQuick
Based on my datalogs of 2nd gear pulls on the street, I am seeing an 11% increase in airflow @4500rpm and 8psi with just the screen and wastegate dumped to atmosphere. I suspect I'll see 20% with the cutouts open. Signs are promising...
Old 05-26-2017, 12:20 AM   #11
AGP Turbo
That's a solid gain. If your turbo the ballbearing that will help too. Less drive force needed will mean more air goes out your now free flowing exhaust and less has to go into the 3" down pipe.
Old 05-26-2017, 07:48 AM   #12
RealQuick
Pics of the wastegate dump attached.
Old 05-26-2017, 07:50 AM   #13
RealQuick
I agree, but if I spend the money on another turbo, it will be a bigger one and I will fab my own turbo kit for it.
Old 06-03-2017, 11:38 AM   #14
RealQuick
Decent day today. Had lots of issues, one being clutch slippage in the mid range, some break up in the high rpms, my cutouts stuck open, and I couldn't run under 13psi.
In the end, I made 817rwhp/758rwtq @16psi. I feel like it would have hit 850rwhp with no changes if it wasn't breaking up in the higher rpms.
So, even with the issues, I made 114rwhp more with the changes I made.
No knock... maybe spark issue, valvetrain issues? I dunno.
Duty cycle at 64%
