01-28-2017, 08:09 AM | #1 |
Drives: 2017 Convertible 2SS Join Date: Jan 2017
Front Quarterpanel Emblems
I have a 2017 Conv. 2SS and was wondering if anyone noticed that the front quarter panel Camaro emblems were crooked. Driver side looks like its angled with panel line slightly off-horizontal, but the passenger side looks to be angled more not even following panel line. I'm thinking of asking dealer to fix. Any insight?
01-28-2017, 08:16 AM | #2 |
Drives: 16 2SS 6MT NPP MRC / 15 K1300S Join Date: Mar 2016
Never noticed, but I believe you would be assuming a large risk in reaping more harm than good by asking a dealer to correct that.
Rohana RFX-5 10/11, M/T 275/305, Eibachs, Hellwigs, Hurst SS, DMS LT4 SC 596HP/589TQ, DMS Low-side, Kooks 2LTs, MBRP Race, Rotofab, MMS CC |
01-28-2017, 11:11 AM | #3 |
Drives: '16 1SS Join Date: Dec 2016
A hair dryer, fishing line, tape measure, masking tape, and a good quality double sided sticky tape; and you can do it yourself. And you are going to need some rubbing alcohol and cotton balls. Plus it will most likely be straighter and match side to side. If you are as OCD as I am about those kind of things, this would be the way to go. JMHO
01-28-2017, 05:48 PM | #4 |
Drives: 2016 Camaro SS, Nightfall Grey, 6M, Join Date: Sep 2016
Took mine off, think the car looks much cleaner w/them...
01-28-2017, 06:56 PM | #5 |
Drives: Chevrolet Camaro SS Join Date: Mar 2015
You mean the front fender?
The quarter panel is what's behind the door circling the rear tire |
01-28-2017, 07:27 PM | #6 |
oh crap,they put his quarter panel in the wrong place.its no wonder the emblems are wrong...
01-29-2017, 09:27 AM | #7 |
Drives: 2017 Summit White 2SS Join Date: Jan 2017
They put my passenger one on crooked. Getting the dealer to do it was like pulling teeth so I think I'll have to do it myself. Thinking of removing them altogether
01-29-2017, 01:32 PM | #8 |
Drives: corvette Join Date: Jan 2017
Those things are hideous. I am getting some custom 1LE emblems put on tomorrow
01-29-2017, 01:46 PM | #9 |
Drives: 16 Summit white, Ceramic white 2SS Join Date: Jan 2016
01-29-2017, 06:03 PM | #10 | |
Drives: 2021 LT1 10 speed auto Join Date: May 2013
If you want to remove them, take heat gun, heat up the emblem, and just pull it off. Or take a piece of fishing line an saw it off. |
01-29-2017, 06:16 PM | #11 |
Drives: 15 SilveradoLTZ,162SSVert BlazerRS Join Date: Dec 2015
Looks better with NOTHING on the FRONT FENDER!!!!!!!!
01-29-2017, 06:32 PM | #12 |
01-29-2017, 07:09 PM | #13 |
My bad on calling it the quarter panel...Thanks for the replies.
01-29-2017, 07:13 PM | #14 |
Quarter panel:
A quarter panel is the body panel (exterior surface) of an automobile between a rear door (or only door on each side for two-door models) and the trunk (boot) and typically wraps around the wheel well. The similar front section between the door and the hood (bonnet), is called a fender, but is sometimes incorrectly also referred to as a quarter panel. I should have called it the bonnet! |
Tags |
camaro emblems crooked |
