dave@hennessey
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Engine | Drivetrain | Powertrain Technical Discussions > V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6)
Old 12-13-2016, 11:34 AM   #1
RealQuick
Drives: 2010 Camaro 2SS M6 - Intake/Exhaust
Need help with slave cylinder removal - 2010SS
Having trouble disconnecting the hydraulic line from the slave... which is stopping me from pulling the slave off the input shaft. It looks like there is a little clip that needs to come out in order to pull the line out of the slave? Is this true? The gap is so small where this clip is, that i dont think I have a tool to get in there.
RealQuick is offline   Reply With Quote
Old 12-13-2016, 01:19 PM   #2
2010_camaro
2010_camaro's Avatar
Drives: 2014 Camaro SS
Hey can you send me a picture of the clip you took out of the line?
MODS 6.0 forged iron block, TH400, B&M shifter, DSS axles & driveshaft, Viking / BMR suspension, Full custom fuel system with cell, Twin 76mm teriyaki tornados on 24lbs.
https://www.instagram.com/whoopa_ss/
2010_camaro is offline   Reply With Quote
Old 12-13-2016, 03:22 PM   #3
RealQuick
The clip on the line outside the bellhousing or inside the bellhousing? I am having trouble getting to what looks to be a clip at the attachment point on the slave cylinder inside the bellhousing.
Old 12-14-2016, 06:46 AM   #4
MA2010SS
Drives: 2010 Camaro SS
Pretty sure you need a pick tool to get that clip freed up...that's what I used when I did my install a while back. There is probably another tool out there that can be used also
link to my install a while back
http://www.camaro5.com/forums/showthread.php?t=243571
2010 Camaro SS Whipple SC, CAI Inc Intake, TSP 1 7/8" LT headers no cats, 3" magnaflow exhaust, HPT, RX Catch Can, LSR Toe Rods, LSR Trailing Arms, ALKY Control Meth, McLeod RXT Twin Disc, ZL1 fuel pump, 3.73 ZL1 Differential Kit, BTR PDS Stage 2 Cam, Tuned by SLOWHAWK Performance Bridgewater MA
MA2010SS is offline   Reply With Quote
Old 12-14-2016, 07:39 AM   #5
RealQuick
Thanks for chiming in. I ended up cutting the line to allow me to get the slave off the input shaft so i could get a good looker the clip. I got the clip off once I figured out what kind of clip it was.
I have new lines coming with the street slayer
