06-14-2022, 01:22 PM | #1 |
Drives: 2017 zl1 ,2010 SS /RS L99 Join Date: Sep 2017
Weld wheels question
This question has probably been answered prior , but I wasn’t able to find the answer or didn’t know where to look so just wanted to know. I have a set of welds 17x10 with Mickey Thomson et street ss 305 x45x17 on my 2010 camaro rears . Will I be able to put them on my 2017 zl1 or do I need to modify anything? Any input will be greatly appreciated.
2017 zl1 - rotofab CAI , PDR , Nav .
2010 camaro SS - Procharger D1 sc (Stage 2 with upgraded intercooler)+ whole lot of other goodies ( too many to list ) Last edited by Slvr-camaro15; 06-14-2022 at 01:46 PM. |
06-14-2022, 04:37 PM | #2 |
What is the offset of your 17x10’s? +43?
Originally Posted by arpad_m - “Aww, yet another oil thread with almost the same question in the OP“ Last edited by Trochoidal; 06-14-2022 at 05:27 PM. Reason: Added +43? |
06-14-2022, 05:27 PM | #3 |
Oh man !! I’m not even sure . I purchased them from someone, only thing I know is I had to tie the e brake cable on the 5th gen camaro ss so it would rub on the inside of the wheel. I’m sorry , I wish I had more info to give you.
2010 camaro SS - Procharger D1 sc (Stage 2 with upgraded intercooler)+ whole lot of other goodies ( too many to list ) |
06-14-2022, 05:33 PM | #4 | |
On the SS’s it’s a good idea to relocate the wiring harness on drivers side just to be safe. Maybe a 30 minute job. It might not need it on the ZL1. For reference: https://www.camaro6.com/forums/showthread.php?t=485975
06-14-2022, 06:09 PM | #5 |
Drives: 2022 zl1 Join Date: Apr 2021
Go to tire rack on the net and see the offset center hub etc.For both models .You ll get your answer.
06-14-2022, 06:22 PM | #6 | |
I have both, don’t drive the ss much , enjoying the zl1 for now!! The rear tires on the zl1 are a bit worn out so wanted to put the welds on there instead of spending another 700-800 on new set of tires.
06-14-2022, 06:23 PM | #7 |
Gotcha !! Thank you
06-15-2022, 07:41 AM | #8 |
Drives: Turbo 6.2 Join Date: Feb 2019
id just test fit it in the garage. should take 5 min
2016 Turbo Camaro SS - 800hp/900tq 9.7@146
2018 LTZ Z71 Redline Silverado - 381hp/420tq 13.8@100 |
06-28-2022, 06:49 AM | #9 |
Update
It’s a success . I was pleasantly shocked hearing about the rubbing etc . I didn’t have to touch or modify anything!! It’s a blessing !!! Bolted right up and no scraping, no weird noises or anything !!! Loving it !!! THANK YOU EVERYONE FOR all your advice!!🙏🏻🙏🏻🙏🏻🙏🏻
06-28-2022, 06:10 PM | #10 | |
06-28-2022, 07:11 PM | #11 |
Thank you so much 🙏🏻🙏🏻🙏🏻
For straightening up the image as well 🙏🏻🙏🏻🙏🏻🙏🏻
06-28-2022, 07:14 PM | #12 |
Added oem mudguards
What you guys think ??
06-28-2022, 08:54 PM | #13 |
You’re welcome.
I’m a fan of the color, wheel setup and the OEM mud guards!
06-28-2022, 09:44 PM | #14 |
Yessss !!! Thank you !!! Your setup looks killer 🔥🔥🔥🔥
