06-14-2022, 08:41 AM | #29 | |
Drives: 2020 Camaro 2SS A10 Join Date: Jun 2018
But my shop said the X-Pipe was a bit of a pain, but they made it work without much issue. Only real issue I had with the X-Pipe was when the pipe settled it was rattling against the cross member brace (they "shimmied" the cross member brace no rattling issue now)
2020 Camaro 2SS A10 | Rebuilt by: CBI Street Cars | 2" SE LT Headers | 3" SE X-Pipe | 3" MBRP Axle-Back | Pri & Sec Cat Deletes | K&N Typhoon CAI | LT2 Ported | 95mm ZR1 TB | DOD Delete | BTR Stage I Cam | ECM, TCM & E85 |Tuned by: Shane Hinds | Dyno: 510 rwhp 472 rwtq
06-14-2022, 01:51 PM | #30 | |
Drives: 2019 Camaro SS Join Date: Jun 2022
Of note, Vengeance Racing says they use Kooks headers because they've tested them for fit, no rattling, no chassis mods, just drop right in. They have NOT tested the SE headers and thus won't install/warranty them as one of their packages. That doesn't mean the SE's are a fit nightmare, but it also doesn't mean they're not. Can anyone else comment on fit for Speed Engineering long tube headers as far as installation difficulties? Any chassis mods? Rattling? I really, really want to get the SE ones given the enormous savings over the Kooks, but I sure as hell don't want to inherit something that is a headache later due to poor fit/construction/durability/whatever. Thanks! |
06-14-2022, 02:26 PM | #31 | |
Drives: 2020 LT1 M6 Join Date: Jan 2016
06-14-2022, 03:10 PM | #32 | |
06-15-2022, 08:11 AM | #33 | |||
Drives: Turbo 6.2 Join Date: Feb 2019
CSP headers = best fitment $1,700 Remove steering shaft. Leave the engine and trans alone. Both go in from the bottom. https://www.cspracing.com/complete-s...ro/csp-camaro/ Stainless works $1,150 Remove steering shaft. Guy had to remove valve cover, remove coils, remove coolant tank, loosen engine mounts, loosen trans mounts, had to lift engine. Passenger side goes in from the top. Drive side from the bottom.
2016 Turbo Camaro SS - 800hp/900tq 9.7@146
2018 LTZ Z71 Redline Silverado - 381hp/420tq 13.8@100 |
06-15-2022, 08:23 AM | #34 | |
You don't do that with Kooks Headers, or CSP. Unless that is ALL you are going to do in terms of budget. I understand fitment is a big detail for people. But 2" Speed Engineering had no fitment issues on my car. Why would I pay $1700+ for headers that fit the same when these SE headers ran me $550. And I had a higher performance gain with my budget parts than my pro shops SP525 package for $5500. If you are going to add power for $3000-$4000 you can do a lot more by just saving some money on the headers alone. $3000 for 25hp gain is not my idea of bang for buck. And as I mentioned earlier, head to head one header is the same as another. The difference really is rather or not you want a Sony DVD Player, or a Toyo DVD Player. Now 60rwhp gain for $3500 would be considered bang for buck. And that is inclusive of all parts, install, and dyno tuned out the door. If you find the right shop of course.
06-15-2022, 08:33 AM | #35 |
right on
06-15-2022, 09:02 AM | #36 |
I guess to be fair. People who can do Kooks headers probably do their own labor. But, for someone who isn't that mechanically inclined like me. Kooks were not a budget option.
06-20-2022, 03:49 PM | #37 |
So I'm now in a bit of a bind on choice.
On one hand, I have Vengeance Racing. Their Stage 1 package has Kooks long tubes + X pipe, Rotofab CAI, a catch can, 180-degree thermostat, tune, plus a few other things like a warranty. All-in cost is around $7500...which seems like a lot of money for not that much stuff. They will not install anything but Kooks long tubes. They're also booked solid until at least September. On the other hand, I have Injected Engineering which is only a couple of miles from my house. They generally stick to Mopar and Ford, but they would do a header/X-pipe + Rotofab + tune for me. No warranty, no coat on the headers, no catch can, no additional goodies. Problem is they want to go with Stainless Works headers and want to charge north of $6000. This also seems extravagant. Is this just what I should expect these days? Vengeance didn't itemize their costs, but Injected did. They put in $1200 for labor to install headers alone...which is more than a set of Speed Engineering COATED long tubes will probably set me back. Can someone weigh in on whether these costs are considered out of line? The things I really want are: - coated headers, installed, with X-pipe - Rotofab CAI - Catch can - Tune Paying $6500-$7500 for that just seems like...a lot. I had heads ported/polished, 2.02/1.60 swirl polished, three-angle undercut stainless valves, headers + cats, rockers, cam, MAF, 3.73 rear end gears, and a tune put in my 1996 SS Camaro for about $12k. I was making about 400rwhp off that. Yes, that was about 15 years ago but that's a helluva lot more work and results than this would be. I've never installed headers before but if these are the going rates, I may consider trying it. Either that or someone suggest a decent shop that doesn't charge $1200 to install some headers. |
06-20-2022, 04:46 PM | #38 |
Drives: like an old lady Join Date: Jun 2012
title of the thread is best way to spend 3-4k. last post showing 6-7500. so which is it?
i would opt out of the "180 t stat". the factory tstat in my 18 1LE holds coolant temps at 178 while going down the road. i imagine the ss is the same. i did 2" speed engineering headers on my car, worst part is the x pipe. the headers are great, been on there over 2 years and 20k miles. unless you have baby hands, you'll want to remove things like the coolant tank & coils, steering shaft etc during install. there is very little room. it makes things easier and lessens the chance of breaking something else. if you buy speed engineering headers i highly suggest you get v bands on them prior to installation. unless youre good with a welder, you'll need to find someone to install the v bands and cut/modify the exhaust for you.
06-21-2022, 07:41 AM | #39 | |
Drives: E92 BMW M3 Join Date: Oct 2012
Good luck man, wish you had more choices near you.
J-Rod Built and Matt@FSP Tuned |
06-21-2022, 05:10 PM | #40 | |
Race Trac 840 Church St. NW Marietta, Georgia 30060 I ask because knowing what I know now I’d buy: 1) LT2 manifold ready to bolt on with adapter ($443 - GPI or used) 2) 95mm TB ($179 - Rock Auto) 3) E85 kit ($399 - Jannetty) $1021 total. Pay someone to put it on the car if you can’t. If you can’t get in until September for tuning, use onE of the sponsored vendors for remote tuning. You’ll learn more about logging your car, saving tunes and writing tunes. Plus you’ll be within your budget. This will give your the best bang for your money spent. I know there are no headers or RF in the list but this would get you started until round 2 of upgrades.
06-22-2022, 06:38 AM | #41 |
I have to disagree with putting a 95 onto an 87mm manifold, because it would not give the full benefit of the 95. Instead, if you really like the LT2 manifold, then I'd suggest getting the full-boat ported one from GPI that is modded for a 95 throttle ($869 with an adapter). Also then specify the adapter as the 95 straight one, NOT the 95 to 87, which is actually a restrictor plate. Benefit of the 95 is larger hole for more airflow, but then you're going to choke it down? No thanks. The max-effort modded LT2 should be nearly as good as an out-of-the-box MSD, and the price at 869 is lower than an MSD, addressing budget concerns.
06-22-2022, 06:55 AM | #42 | |
