05-10-2022, 07:48 PM | #1 |
Drives: 2013 2SS/RS Convertible Join Date: Apr 2016
Where does this go?
It says there is a pop off cover, which I have seen on other cars, but not on a 5th gen. I’m guess you’d have to cut a hole in the bumper?
05-10-2022, 07:53 PM | #2 |
Drives: 2010 Camaro 2SSRS M6 Join Date: Jan 2019
Mine does not have one either. I have the ZL1 addons version and it mounts perfect to slide between the slots. I can take a better picture if needed this is a screenshot of a video. I marked where it needed to go before I removed the front bumper to install the bracket.
ECS supercharger, custom ground cam, ported throttle body, long tube headers, aeromotive fuel pump, fic injectors, ATI super damper, Corsa Extreme exhaust, elite engineering catch can and many other things.
05-10-2022, 07:57 PM | #3 |
Yes please do!!!
Thanks. |
05-10-2022, 08:06 PM | #4 |
Drives: Car Join Date: Jan 2013
That’s EXACTLY what you have to do. There’s some good write ups here if you search. The most important step is mark it BEFORE you remove the front cover and start drilling. Placement is not to far towards the outside but you don’t need it centered…it’ll look stupid. So about 12-18 inches from center…whatever you think.
05-10-2022, 08:42 PM | #5 |
Car is filthy but here are some more pics. In the first pic you can see the bolt holding the mount and the threaded insert for the hook. Maybe this will help.
05-10-2022, 08:46 PM | #6 |
Thank you!!!
05-10-2022, 09:08 PM | #7 |
05-11-2022, 05:03 AM | #8 |
Drives: 2014 Camaro 2SS/RS 1le Join Date: Jan 2017
This is what you need. You have to pull the front bumper and install the support with the threaded insert. Once again GM in their infinite wisdom put in the removable cover with no threaded bumper support behind the cover.
https://www.carparts.com/details/Che...E&gclsrc=aw.ds
2014 Camaro 1LE SS/RS THE MISTRESS
05-11-2022, 06:03 AM | #9 | |
Evil Genius of Chevrolet
Drives: 2017 Z06, 2019 XTS, 2013 SS Join Date: Feb 2017
GPI SS2 VVT cam, ECS Novi 1500 supercharger, Corsa Extreme, Detroit Speed and BMR suspension, Circle D triple disc, Melling oil pump, LS2 chain tensioner, ATI 10% UD, DSX E85 kit, High Energy coils, BTR springs, LS2 Lifter trays, Titanium retainers, hardened push rods, FIC 1000 injectors, ZL1 pump, Mighty Mouse catch can, AEM gauges, Tial BOV, Richmond 3.91 gears, Custom gauge bezels, Speed Engineering headers, Stainless Works HF cats, DSX Aux pump, 710rwhp on E85.
05-11-2022, 07:25 AM | #10 |
Drives: 2011 1SS/RS IBM Camaro Join Date: Jan 2011
I have the ZL1 on my 2011 also no drilling. The newer camaro has to have the crash bar replaced it has the threaded hole already for mounting the Tow hook.
05-11-2022, 08:42 AM | #11 |
not afraid of the wall
Drives: Camaros Join Date: Apr 2010
I went with the JDP due to being a 2013. Otherwise, had I owned a 14/15, I’d get the threaded one and swap crash bars.
2023 1LE 1SS BCD GCF JF5 MN6 SIA SLN UQT
10/13/22: 1100 Past Camaros: 13 1LE|02 SS|01 Z28|00 SS|91 1LE|91 Z28|89 IROC-Z |
05-11-2022, 03:21 PM | #12 |
Then you would have to cut a hole out of your bumper cover
05-11-2022, 03:27 PM | #13 |
Drives: 14 Camaro LS Join Date: Apr 2017
My 14 1Le had a removable cover over the spot you need to drill for the insert. I can remove the hook and put the cover back on and it's like it never happened.
Sent from my SM-S908U using Tapatalk |
05-11-2022, 05:42 PM | #14 |
Drives: 2010 SS Join Date: May 2014
