04-24-2022, 08:47 AM | #1 |
Vibration/ Chattering Down Track
Did the same thing two weeks ago. so I changed all tires but still does it. "Chattering " is the best description, almost like it's losing traction.
TC and Stabilitrak were off. Will make hits this morning with Stabilitrak on. Ideas?
'20 ZL1 1LE A10,
04-24-2022, 09:30 AM | #2 |
Drives: like an old lady Join Date: Jun 2012
1000+ hp, in a rock hard chassis, on the street while using a stiff sidewall road race tire?
i rode in a 950 whp supra that was doing this at 100+ mph. we thought it was wheel hop.
04-24-2022, 09:51 AM | #3 | |
Also, where could I see this vibration in HPT data?
'20 ZL1 1LE A10,
04-24-2022, 09:53 AM | #4 |
Is it under hard acceleration only or all the time even when just cruising at hwy speeds?
2016 NFG 1SS A8
04-24-2022, 09:58 AM | #5 | |
It shakes so badly down track (prepped track) you think of aborting the run.
'20 ZL1 1LE A10,
04-24-2022, 10:01 AM | #6 |
is the track bumpy?
04-24-2022, 10:03 AM | #7 |
It's the Mile High Nationals track and I didn't hear anyone else complain, so It seems unlikely. I'm going back up at 1000 this morning to make a few hits, maybe with more air pressure.
'20 ZL1 1LE A10,
04-24-2022, 10:10 AM | #8 |
that was my next question. what does that beast run? i missed your timeslips.
04-24-2022, 01:19 PM | #9 | |
10.927 129.78 I removed Antigravity and put the stock battery back in it, and increased tire pressures rear and front. No vibration. It's still a slug on the hit/ 2nd gear. I suppose I need to try max rpm foot braking or 1st gear launch. Per NHRA factors, 10.92 at 6500 DA corrects to 10.04 at 0-1000 ft. But this car only has six runs total, and only three w/o electrical and air issues. It lost all power yesterday in the pits. I think it'll be a 10.50s car up here.
'20 ZL1 1LE A10,
OEM short block, LME heads/valve train, E2650. 100+ octanes, no eth, no meth, no N2O. 2/23 - 1031/1004 wheel. 4/23 - 1.41/9.61/145 at DA 7000 ft. (only made five passes). 2/24 - LME 390, E2650, FBO, 100 oct.; 1116hp/ 1063tq; 109 oct. dyno next. Last edited by JSH; 04-24-2022 at 01:30 PM. |
