03-10-2022, 03:37 PM | #1 |
Drives: 16 2SS Join Date: Nov 2021
Pop when making sharp turns.
Took the car to the track for the first time since I bought it back in Oct. Made 3 passes with it. After the first pass i heard it pop when going around a car in the lanes but, didn’t pay any attention to it. When going home i noticed it would pop when making sharp turns left and right and there is a small shift in the the rear end when it pops. Has anyone had this issue before?
03-10-2022, 05:36 PM | #2 |
track as is in road race or drag or?
03-10-2022, 05:46 PM | #3 |
Most likely drag racing. OP, did you check your rear wheels and lugnuts?
03-10-2022, 10:25 PM | #4 |
Took to the drag strip. Sadly, there isn’t a road course near me. I did not check the lug nuts. I will look at that. The car has probably 25 -30 street passes with the draggy but, the first pass at the strip it hook better that I thought it would. I’m going to put in on the lift tomorrow if I get a chance and look around. Hoping it something simple.
03-11-2022, 01:38 PM | #5 |
Well, took it to my dads shop and the clutches are sticking in the rear differential. Gotta get some fluid and additive so we can crack it open.
03-11-2022, 06:47 PM | #6 |
How did you determine that?
03-12-2022, 11:17 AM | #7 |
He drove it. Listened to how it would pop only when turning. He has been a ASE certified tech since the 90s. Rebuilds differentials in just about anything. Has also raced just about anything with a engine in it.
03-12-2022, 12:31 PM | #8 |
Ah nice. A lot of use are using the oe fluid that is premixed with additive. So the amount is correct and don’t have to mess with having too much or too little
