Old 10-01-2021, 06:40 PM   #1
17MaroSS
Drives: 17 2SS 6sp
Permanent water spots!!!
I left my black SS out on the driveway for 2 months in the dead heat and got rained on many times. Just washed the car twice, large nasty water spots do not come out. I'm not surprised by this nor am I proud of my unforgivable sin. Is there anything else I can do here aside from a paint correction? Thanks
FOR SALE 17 2SS 6spd h/c/i/fbo
17MaroSS is offline   Reply With Quote
Old 10-01-2021, 06:42 PM   #2
kropscamaro16
kropscamaro16's Avatar
Drives: 2016 1ss camaro
ive used this in the past on my old car i would try this before taking it to a shop
https://www.amazon.com/Meguiars-Wate...66713279&psc=1
Old 10-04-2021, 01:48 AM   #3
peteric
Drives: 2016 camaro
If the water spots have etched the paint, a polishing product or ultra compound is what you need.
peteric is offline   Reply With Quote
Old 10-04-2021, 05:39 AM   #4
CamaroDreams76
Tri-County Camaro SWFL
CamaroDreams76's Avatar
Drives: 2013 IOM 2SS/RS/1LE
2 months of sitting with water spots. You would be hard pressed to get those out without polishing. Might as well try a water spot remover.
CamaroDreams76 is offline   Reply With Quote
Old 10-04-2021, 05:44 AM   #5
Spaceme1117
Spaceme1117's Avatar
Drives: 2017 Camaro SS, 2011 Corvette GS
As others have said, some Meguiar's polishing compound should take care of it.
And then to prevent further spots and to keep your car cleaner longer, I would recommend the Meguair's Waterless Car Wash and Wax. I have been using this for the past couple of years on my cars and it's great. Save a lot of time from having to hand wash and water just beads right off. Doesn't get water spots either.
Spaceme1117 is offline   Reply With Quote
Old 10-04-2021, 10:04 AM   #6
m6-lt1
m6-lt1's Avatar
Drives: 2023 Chevrolet Camaro 2SS 1LE
Don’t waste your time with water spot removers. Don’t waste your time looking up “tricks” to remove water spots either. These types of water spots that you have only have one method of removal. That is you must polish them out as others have stated. This is not the end of the world of course. You have 2 choices, pay a detailer to do it or buy a Da polisher, watch YouTube videos, and do it yourself. The second method is what I did and it worked pretty well. Just make sure to ask any questions you have and make sure to follow the process exactly as you watch.
m6-lt1 is offline   Reply With Quote
Old 10-05-2021, 09:58 AM   #7
WhiteMale
Drives: 23 ZL1 A10 Rapid Blue
Id' go clay bar as a trial before I went to a polish and/or buffer
Old 10-05-2021, 01:47 PM   #8
Outahand
Drives: 2018 ZL1
Some vinegar on a rag took water spots right off mine.
I do have ceramic coating on the car.
Mark E.
2018 ZL1 NGM A10
87 Grand National. Modified Hot Rod for sale *SOLD*
87 Grand National. Stock
65 Olds Vista Cruiser wagon Grand National motor/tran
66 Bronco Rockbuggy
2006 Dodge 2500 4x4 Cummins 6 speed
Outahand is offline   Reply With Quote
Old 10-06-2021, 12:15 AM   #9
Gunkk
Thank you Al Oppenheiser!
Gunkk's Avatar
Polishing is the best bet.
You can try CLR or Carpro Spotless, but odds are they won't be enough.
