07-06-2016, 03:12 PM | #29 |
Drives: 2016 Camaro 2SS (on order) Join Date: Mar 2016
"curb feelers"
2016 Camaro 2SS Garnet Red
V8, Dual Exhaust, MRC, Nav, Sunroof, Loaded "Ahhh! Take care to get what you like or you will be forced to like what you get!" - Lyrics from a song from Scooter: "Apache Rock the Bottom!" Previously owned 1998 BMW 540 w/M-series package 1991 Trans Am GTA 1985 Saab 900 Turbo (Burned leaded fuel on the Autobahn) 1985 Firebird (R.I.P.) 1976 Camaro LT |
07-06-2016, 03:19 PM | #30 |
Drives: 2016 Black SS Join Date: Dec 2015
These have two large impacts on the car...brake cooling and aero. They direct air out from under the car, helping to create an area of negative pressure under the car, pulling it downward.
07-06-2016, 03:55 PM | #31 |
Drives: 2020 rally green rs Join Date: Oct 2013
And I think you are correct sir!It definately has something to do with what G.M. designers call=Air management-like it or not!
07-10-2016, 04:25 AM | #32 |
Drives: 2022 Satin Steel ZL1 M6 Join Date: Sep 2015
If the ones that are on the car are only effective over 125 mph and the ones that come in the trunk for track use are designed for directing more air towards the inside of the front brake discs why not always drive with the track ones and keep your brakes cooler, since you will rarely ever be over 125 mph?
07-11-2016, 10:14 AM | #33 | |
Drives: 2SS, Hyper Blue Join Date: Feb 2016
Longer brake "scoops". There are some downsides to running the Track scoops on the street. Refer to your manual. There is a of incorrect info out there about both.
Steve
Hyper Blue 2SS, 6M, NPP, Sunroof, Nav |
07-11-2016, 10:31 AM | #34 |
Drives: SUMMIT WHITE 2016 1SS NPP 6MT MRC Join Date: Jan 2016
My question is should I remove the front air dams at the track? They appear to block a lot of air flow to the "track brake deflectors", but I will most definitely be over 125 mph at the track.
07-11-2016, 10:33 AM | #35 |
Your owners manual says to remove them when the track brake deflectors are fitted.
Steve
07-20-2016, 11:33 PM | #36 |
Drives: Corvette Join Date: May 2016
My 1ss didn't come with them. Should it have?
07-21-2016, 07:44 AM | #37 |
Drives: 2016 2SS Join Date: Nov 2015
07-21-2016, 10:34 AM | #38 | |
Check that the rear lower arm suspension covers are in place also....I'm guessing they skipped them too.. Read: http://www.camaro6.com/forums/showthread.php?t=442990
Steve
02-23-2017, 04:27 PM | #39 |
Drives: '17 1LT RS V6 6M NPP Join Date: Apr 2016
I'm dumb. Can anyone help? I like the way these look, and I took mine off for winter, afraid they would rip off plowing snow. Now I'm ready to put them back on and I've misplaced the screws...
Does anyone know what these pieces are officially called? Maybe I can find a parts diagram or something online. I want to buy the right screws w/ the proper thread pitch and diameter. |
02-24-2017, 06:33 AM | #40 |
Drives: 2016 1SS (12/10/2016) Join Date: Jul 2015
I apologize if this comes across as silly, but did you look in the holes that they came out of?
If you followed the instructions in the "Preparing for Track Use" paper, you are supposed to remove the deflectors before track use. After removing the screws, and then the deflectors, you put the screws back in the holes in the bottom of the car. I believe the screws actually do more than just hold the deflectors on, I think they hold a couple more pieces of the underside of your car together. Take a peek underneath, hopefully they are still in there. |
02-24-2017, 07:31 AM | #41 | |
Actually, now that I'm typing this, I think I know where they are! I took the deflectors off when I swapped out my stocks for winter wheels/tires and I believe I put them in the box along with the lugs for my stock wheels. They're at my brothers house in his attic with my wheels. |
02-24-2017, 10:36 AM | #42 |
Drives: 2020 SHOCK SS 1LE Join Date: Sep 2016
I have no issues leaving them on plus I'm actually careful when I enter and exit driveways.
Besides deflecting air there was instance where I could not avoid a piece of debris on the road. Thankfully because of the air deflector the object was pushed out and away instead of getting caught underneath my car and possibly causing damage. I also feel that during heavy rain when you can't avoid driving through a fairy deep puddle the water is first pushed away from the tire by the deflectors. To me that equals a safer drive. I like them because they actually DO serve the purpose of DEFLECTING and they look fine. |
