01-08-2021, 11:04 AM | #29 | |
Drives: 2023 ZL1 Vert M6 "Sharky" Join Date: Mar 2020
EDIT: Maybe an anomaly I have only changed it once. I will be doing it again in the spring and will report back. Last edited by FarmerFran; 01-08-2021 at 11:14 AM. |
01-08-2021, 11:39 AM | #30 |
Drives: Former 2016 Camaro 1LT Join Date: Jan 2017
I change mine when it's about 30%. It usually equates to about 4500-5000 miles, 2X a year. I don't usually go more than that. My Camaro takes only 6 quarts and I get my oil filters from Rock auto so it doesn't really cost that much to change it.
2006 C6 Corvette Manual, 2019 Silverado, 1997 Jeep Wrangler
01-08-2021, 11:41 AM | #31 |
Hot Camaro
Don't believe Autozone sells any dexos2 oil... Might want to check the bottles. The Mobil 1 European Car Formula is -not- dexos2.
01-08-2021, 11:44 AM | #32 |
Faster!!!
Drives: 2020 Camaro 1SS 1LE Join Date: Mar 2020
Around here Mobil 1 0-40 Dexos 2 is only at dealerships, or online. No stores have it
01-08-2021, 12:26 PM | #33 |
Drives: '19 ZLE, S54 E36M3 Join Date: Feb 2018
The OLM seems to be pretty smart. Mine went from 100% to zero in just four track days, or about 500 miles. I'd trust what it says.
01-08-2021, 12:44 PM | #34 |
'20 ZL1 1LE A10,
01-08-2021, 01:14 PM | #35 | ||
Drives: 19 Chevrolet Camaro 2SS 1LE Shock Join Date: Apr 2020
I did have the first 2 oil changes happen early due to the amount of metal particles in the engine during break-in. I can see some small bits on the dipstick. They are all gone at this point, and so I won't be worrying about it. Quote:
Sent from toaster or something
Current:
2019 Chevrolet Camaro 2SS 1LE M6 Shock GM Performance Intake and that's it, because driver mods before car mods Past: 2009 Mazda RX-8 GT M6 Velocity Red Mica (Sold) 2015 Chevrolet Corvette Z51 2LT M7 Velocity Yellow Tintcoat (Flood totaled) |
01-08-2021, 01:17 PM | #36 |
Drives: 2017 Mosaic Bk ZL1 M6 Join Date: Jul 2009
I only put 2000-5000 miles/year on so change once per year. Interestingly, on these cars, if you put 0 miles on them in 1 year, your oil life will still go to zero. My Silverado doesn't do that.
01-08-2021, 06:16 PM | #37 |
Drives: 2020 Camaro LT1 MM6, NPP Join Date: Feb 2020
Hey guys! Once a year or 5K miles period!
01-08-2021, 06:57 PM | #38 |
I tend to agree with that especially if you don’t track your Camaro!
01-08-2021, 06:59 PM | #39 |
Drives: Chevy Camaro Join Date: Apr 2020
Dip your oil and have it tested. Then you will know. Most oil companies have a free/low charge program for this service
01-08-2021, 07:10 PM | #40 |
Drives: 2011 2SS/RS LS3 Join Date: Nov 2011
This is from my 2011 manual...
Engine Oil Life System When to Change Engine Oil This vehicle has a computer system that indicates when to change the engine oil and filter. This is based on engine revolutions and engine temperature, and not on mileage. Based on driving conditions, the mileage at which an oil change is indicated can vary considerably. For the oil life system to work properly, the system must be reset every time the oil is changed. When the system has calculated that oil life has been diminished, it indicates that an oil change is necessary. A CHANGE ENGINE OIL SOON message comes on. See Engine Oil Messages on page 5‑36. Change the oil as soon as possible within the next 1 000 km (600 miles). It is possible that, if driving under the best conditions, the oil life system might indicate that an oil change is not necessary for up to a year. The engine oil and filter must be changed at least once a year and, at this time, the system must be reset. Your dealer has trained service people who will perform this work and reset the system. It is also important to check the oil regularly over the course of an oil drain interval and keep it at the proper level. If the system is ever reset accidentally, the oil must be changed at 5 000 km (3,000 miles) since the last oil change. Remember to reset the oil life system whenever the oil is changed And this is from my '17 Impala... Engine Oil Life System When to Change Engine Oil This vehicle has a computer system that indicates when to change the engine oil and filter. This is based on a combination of factors which include engine revolutions, engine temperature, and miles driven. Based on driving conditions, the mileage at which an oil change is indicated can vary considerably. For the oil life system to work properly, the system must be reset every time the oil is changed. When the system has calculated that oil life has been diminished, it indicates that an oil change is necessary. A CHANGE ENGINE OIL SOON message comes on. See Engine Oil Messages 0 133. Change the oil as soon as possible within the next 1 000 km (600 mi). It is possible that, if driving under the best conditions, the oil life system might indicate that an oil change is not necessary for up to a year. The engine oil and filter must be changed at least once a year and at this time the system must be reset. Your dealer has trained service people who will perform this work and reset the system. It is also important to check the oil regularly over the course of an oil drain interval and keep it at the proper level. Chevrolet Impala Owner Manual (GMNA-Localizing-U.S./Canada-9921197) - 2017 - crc - 3/30/16 Vehicle Care 259 If the system is ever reset accidentally, the oil must be changed at 5 000 km (3,000 mi) since the last oil change. Remember to reset the oil life system whenever the oil is changed. Last edited by 90503; 01-08-2021 at 07:25 PM. |
01-08-2021, 07:29 PM | #41 |
Drives: 2020 LT1 Join Date: Nov 2019
I drive 5k a year. after the 1k break in. I change it once a year. with synthetic.
01-08-2021, 08:15 PM | #42 |
Drives: '17 2SS convertible'20 Yukon Denali Join Date: Nov 2011
One thing I haven't seen mentioned, for you guys who have to put your car away for the winter. One recommendation that applies for cars and boats is to not put the engine in storage with dirty oil. One of the byproducts of combustion is that acids can build up in the oil. Moisture also if not warmed up sufficiently. You don't want your bearings and smooth surfaces soaking in acids all winter. Cheap insurance to change before it goes into storage.
Richard
2017 2SS SIM convertible, A8, NPP, MRC, 56R wheels, GM CAI, Diode Dynamics Side Markers Delivered: 08/15/2016 #TeamBeckyD |
