08-09-2020, 08:02 PM | #127 |
Drives: 2019 SS 1LE Join Date: Jun 2018
Is the drain plug gasket supposed to be replaced each change?
08-09-2020, 08:12 PM | #128 |
Drives: 2016 2SS Convertible Join Date: Oct 2017
No, that should not be necessary. The drain plug seal generally will last for years
2016 2SS Convertible; SIM; Black & Ceramic White interior; M6; NPP; DD LED side marker lamps & back-up lamps; LED trunk lamps, license plate lamps & front T/S lamps; 3rd brake light pulser; Skip-shift eliminator; Borla s-type non-npp axle backs; Weather-Tech floor mats, trunk mat, rear license plate frame/cover; GM fuel door; ZL1addons rock guards; Removed fender badges, front & rear SS badges; JLT CAI, tune, oil separator; RP Synchromax in transmission; RP MaxGear in rear differential; GM Lowering Suspension Upgrade; Dimple oil filter magnets & magnetic oil drain plug; 3M Ceramic window tint.
08-10-2020, 07:57 AM | #129 |
08-10-2020, 10:57 AM | #130 |
That works and now you will have a spare seal for when you finally do need to change it.
08-10-2020, 10:26 PM | #131 |
Drives: 2018 1SS 1LE Join Date: Jul 2020
I really didn't want to buy new ramps (raceramps aren't cheap) so I spent $9 for a 2x8 and some time with a band saw and made these. Worked great after I put rubber mats down to keep the plastic ramp from sliding.
Also I had to put almost 10.5 qts in to get it to the top of the hatch on the dipstick.. This was with prefilling the filter too and waiting several hours after the first 10 qts to check it.
2018 1SS 1LE Hyper Blue
08-10-2020, 11:00 PM | #132 | |
2020 Shadow Gray 2SS
2020 SGM 2SS - A10, NPP, MRC, Red Calipers, Black Camaro Fender Badge, Footwell Lighting
Added after delivery: - GMP CAI, GMP Black Strut Tower Brace, MRR017 1LE Wheels, SS Armrest, Black Fuel Door, Stainless Sport Pedals, SS Wheel Caps, Black Lugs/Locks, GM Splash Guards, DD Smoked LED Markers, Smoked Rear Reflectors, Mishimoto Catch Can, Xpel PPF - Full Front, SunTek 35% Tint, CeramicPro coating, RST Stainless Brake Lines, Castrol SRF, MSD Super Conductor Wires Left: My "fun" ride. Right: My "work" ride: a Gulfstream G600. One's top speed is 180 Mph, the other, 620 Mph... |
08-10-2020, 11:06 PM | #133 |
I guess the real question is how accurate are the quart bottles filled. Maybe M1 is underfilling their quarts by .05 quarts! I'll have to check it again.
I have a SS 1LE, its a wet sump as far as I know. but I'm an LT1 noob.
08-10-2020, 11:09 PM | #134 |
I'm using Mobil 1 0W-40 ESP Formula as well...
