01-21-2016, 02:50 PM | #29 | ||
Drives: Mostly Stock Join Date: Jul 2012
Sure does! This is a full bolt-on kit including the catch can, catch can bracket, hardware, and molded silicone lines with quick-disconnect fittings.
Thanks -John |
01-21-2016, 03:19 PM | #30 | |
Drives: 2017 Camaro 2SS 6MT Join Date: Aug 2006
So does this mean in 5 years I'm going to have to have the heads and valves removed and cleaned of carbon for $1500???? I'm not asking you perse, it's a rhetorical question really..... no manufacturer, not GM, not Ford, not Honda, not VW or Audi, should be producing engines with this type of system without acatch can or some other system to keep things from happening. I'm really speaking for the general car customer who isn't a gear head and has no idea the difference between an intake manifold and a garage door opener. Many cars have direct inject now and if there's a problem with that design at high mileage they need to either fix the problem or quit using that design and go back to multi-port fuel injection. If too many people have to pay outrageous bills for valve jobs at 100,000 miles that won't be good. People are reasonable to expect they have to do belt changes and routine fluid changes. Carbon cleaning? All I'm saying is DI should have been well tested before being implemented into mass production. |
01-21-2016, 03:25 PM | #31 | |
01-21-2016, 03:40 PM | #32 | |
マスタング = 遅い
Drives: 2017 Chevrolet Camaro SS 1LE Join Date: Aug 2015
That was the first car I started to use a catch can with...used it on my coyote (VVT, but not direct injection) from day one, it had nearly no oil on the throttle body or in the intake. My buddy with the same car, no catch can, had tons of build up... |
01-21-2016, 03:40 PM | #33 |
Drives: 2x 94:Z28s - 2x95:Z28s - 1x16:1LT Join Date: Nov 2015
I would be curious to see what the spark plugs look like
01-21-2016, 03:47 PM | #34 | |
01-21-2016, 03:50 PM | #35 |
Retired from Car mfrs....
Yes they do. but GM did not put a Catch can on the LT1 so dealers could make more money. GM does not give a damn about dealers making more money, trust me. GM's stance is still the LT1 does not need it. Confirmed over and over and all the Corvette fests in the last 2 to 3 years , it always comes up. I don't have a personal feeling one way or another , just recording what's over on the forums over there. I'm still a Tech contributor there.
01-21-2016, 03:54 PM | #36 | |
マスタング = 遅い
GM started using direct injection over the last few years. Do all C7 owners use catch cans, of course not, most are pretty clueless in most cases. All the C7 owners that I know have a catch can, as do many on Corvette Forums...for $100 or so, it is a great addition. |
01-21-2016, 03:55 PM | #37 | |
マスタング = 遅い
01-21-2016, 03:57 PM | #38 | |
I think my friend Barry on post 16 pretty much nailed it. |
01-21-2016, 04:01 PM | #39 | |
Drives: '95 Corvette, '06 Mustang, 2LT RS Join Date: Dec 2015
http://www.edmunds.com/autoobserver-...-adopters.html
Good article, with one case of documented drop in performance due to build up. Also about how some engines are much less prone to build up. Quote:
Mosaic Black 2LT/RS, V6, manual, dual mode exhaust, heavy duty brakes, adrenaline red, lighting and convenience package, black bow ties
01-21-2016, 08:15 PM | #40 | |
マスタング = 遅い
But... FYI, GM can say what they want to cover themselves, they have done it many times before. The ignition issue ring a bell? They also said C6 Z06 has no valve issues, then made upgrades...just to name a few things engineers said to simply cover their asses. Even GM has realized the LT1 needs it, hence why they added it to the latest LT1. Rumors on LS1Tech are that the Vette will get it next MY too. I've seen the improvements a catch can can make first hand. Lingenfelter, L&M, TSP, RPM, etc, all recommend them.......and Ford even adds two to all GT350's seeing track time. It's your car, do want you want of course... Last edited by SS 1LE; 01-21-2016 at 08:27 PM. |
01-22-2016, 10:42 AM | #41 |
There is a difference between releasing something to customers to about current problems(covering their ass) and submitting something in a SAE publication concluding a project with 100s of millions of dollars of R&D in science and engineering.
Adding a catch can will help coking. GM adding a catch can doesn't disprove what they previously published. Again, the publication states the MAJORITY of coking is from gases reverting back into the intake port during the overlap interval(both valves open). That means a MINOR percentage of coking is from oil in the intake. So adding the catch can will only mitigate that smaller percentage. That still means the catch can does work and likely worth the investment. |
02-28-2016, 07:31 AM | #42 |
Drives: 2020 rally green rs Join Date: Oct 2013
I had a 2002 corvette,changed the oil every 4000 miles,once a year,drove the hell out of it,no catch can,sold it with 94k miles on it NEVER a problem ever,ever!
