Old 10-24-2020, 08:48 AM   #1
11bravoss
Drives: 2018 ZL1
Loose lug nuts!!!
I just switched to 15in D5 beadlocks on my Z and keep getting loose lug nuts after driving only a few miles. Anyone else experience this? I've tried different torque specs.
11bravoss is offline   Reply With Quote
Old 10-24-2020, 02:46 PM   #2
enzia35
Drives: '16 Garnet Red 1SS
What torque specs? 140ft lbs is what the manual calls for.
'16 Camaro 1SS
'18 Miata GT
Old 10-24-2020, 10:50 PM   #3
Alpha1BC
Alpha1BC's Avatar
Drives: 2017 1SS 1LE
And if you're already using 140 ft-lbs for torque, next thing I'd check is that you have the proper lug nut dimensions for the wheels, specifically the dimensions of the taper.
2017 SS 1LE.
Alpha1BC is offline   Reply With Quote
Old 10-27-2020, 09:58 AM   #4
ctrlz
What is the thickness of that wheel in the lug area compared to stock? I think your lug nuts may be bottoming out.
Edit:
I think this guy is right. The website says you need conical/tapered lug nuts:
https://www.forgestar.com/wheels/d5-drag-racing-wheel/
This thread has some size recommendations for VMS drag wheels, which also require a conical tapered nut:
https://www.camaro6.com/forums/showthread.php?t=579308
