Old 03-10-2017, 12:00 PM   #29
AZ_1LE
Drives: 2019 ZL1 1LE
Originally Posted by Iroc_Z28 View Post
I think they added the requirement for 1LE's to get the shipping blocks as well after complaints of splitter damage during shipping. My car was delivered end of December 2016 and i didn't have the shipping blocks or this warning label... luckily mine was undamaged
Explains why mine arrived at the dealership damaged But it just arrived to them at the beginning of February.
Old: 2017 SS 1LE
Old: 2017 ZL1
Current: 2019 ZL1 1LE
AZ_1LE is offline   Reply With Quote
Old 03-10-2017, 12:03 PM   #30
RUQWIKR
RUQWIKR's Avatar
Drives: 1LEs
Originally Posted by slick3 View Post
Which kit did you buy? I dont see one for the 2016 Camaro let alone the 1LE with the big brakes
Just make your own like I mentioned scouring eBay or Craigslist:
- 18x4 aluminum or steel spare from CTS, Camaro, etc.
- Spare 135/80/18 or 155/70/18 spare tire
- 5/16" spacer for use on rear (some spare wheels don't need this)
- For the front, the thick adapter spare like I put in the picture that I just took off the web above or this one
RUQWIKR is offline   Reply With Quote
Old 03-13-2017, 08:51 PM   #31
171LE
Drives: 2017 Camaro 1SS 1LE Nightfall Grey
Well, been with out the 1LE for 5 days now, I think I am slipping into mild depression...
Dealership said 3-5 days on the Nitto 555 G2s, 5 days is tomorrow, so my fingers are crossed.
My spare tire kit comes in tomorrow as well.
I'll post some pics after both have been completed.
171LE is offline   Reply With Quote
Old 03-30-2017, 09:19 PM   #32
Russm
Russm's Avatar
Drives: 1SS 1LE Black, Mazsaspeed 3 Silve
What I am Finding
Looking on ebay / craigslsit and I am finding just this size, but not what you have/recommend above.
Will this work or just keep looking please?
Thank You
What is the thickness of the large spacer please? Bolt Pattern, GM?
08-14 Cadillac CTS 18x4 135/70R18
Russm is offline   Reply With Quote
Old 04-10-2017, 02:35 PM   #33
alpeltier
alpeltier's Avatar
Drives: Will drive a 2018 2SS White Redline
Send a message via Skype™ to alpeltier
I have a question. Would my 1LE take the same rims and tires that come on the standard 2SS. Black rims and run flat tires?
I have a ramp to use and I would like to keep the F1 tires for special occasions. Any mechanical reason why I couldn't do that ? Plus, being an old man, I love spending my kid's inheritance :-)
al
alpeltier is offline   Reply With Quote
Old 05-14-2017, 06:42 PM   #34
WILWAXU
WILWAXU's Avatar
Drives: 2019 Crush ZL1 1LE
Thumbs up
Originally Posted by RUQWIKR View Post
Similar to what I did except I got for free a lightly scratched up aluminum CTS (non-V) 18x4 spare. Tire height is acceptable. Spare pinchweld jack from a GTO with torque wrench and non-marring sockets (for jack and lugs). The jack, wrench, and sockets fit nicely in the foam trunk organizer in the well. Rear needs only a 5/16" spacer to clear. Fronts need the thick adapter. eBay'd all I needed for $100ish. Way better than being stuck somewhere. Take it all out in 1 minute flat when you go racing.
I just put together a similar kit using a 5mm spacer. Here's some shots of the Cadillac CTS aluminum 18x4" spare on the car (proof of concept ).
John Brown
Instagram @wilwaxu
Facebook @wilwaxu
WILWAXU is offline   Reply With Quote
Old 05-14-2017, 07:40 PM   #35
Gilley
Gilley's Avatar
Drives: 16 Red Hot 2SS
^^ Nice work fitting the CTS spare.
'16 Red Hot 2SS A8 sunroof
Gilley is offline   Reply With Quote
Old 05-15-2017, 10:57 PM   #36
TrackClub
TrackClub's Avatar
Seems like a clean solution. What would e-LSD think of this spare? Any concerns? Also, what year CTS is this spare from please? Thx!
Old 05-16-2017, 12:31 AM   #37
crazydmc
ummmm
crazydmc's Avatar
Drives: 2016 2SS M6 Nightfall w/Blk Wheels
Originally Posted by 171LE View Post
Roadside helps, they paid for most of the tow...
Problem was the nearest dealership was in the wrong direction, so I had to pay the difference.
I was nervous when it got pulled on to the tow truck, but luckily it only barely touched the splitter.
the camaro looks bad ass, even on a tow truck
crazydmc is offline   Reply With Quote
Old 05-16-2017, 10:56 AM   #38
WILWAXU
WILWAXU's Avatar
Probably best to move the front tire to the rear if you have to drive any distance.
2007–2014 CTS spare. Be sure to read the description carefully. There are at least 3 different wheel sizes that look similar to this wheel (16", 17", & 18").
John Brown
Instagram @wilwaxu
Facebook @wilwaxu
Old 05-16-2017, 11:02 AM   #39
TrackClub
TrackClub's Avatar
Yes of course, I shoulda thought of that
Thx for the specs.
Old 05-16-2017, 08:56 PM   #40
Tomahawg
Tomahawg's Avatar
Drives: 2017 White SS 1LE
Do you have a part number for that spacer you used on the front?
Tomahawg is offline   Reply With Quote
Old 05-16-2017, 09:43 PM   #41
WILWAXU
WILWAXU's Avatar
I bought it at the Long Beach swap meet.
This one looks like what I have:
https://www.amazon.com/dp/B00KTPE0QG...d=5YXPAC22HWS3
John Brown
Instagram @wilwaxu
Facebook @wilwaxu
Old 05-17-2017, 08:46 AM   #42
FNxR3DNECK
FNxR3DNECK's Avatar
Drives: 2017 SS 1LE
The problem with all this is that running two different size tires in the rear for more than a very short limp home or to the dealer could result in damage to the eLSD. It does not like having two different diameter tire, that's the you MUST replace both rear tires if you get a nail/cut/etc. in one of them.
IG: @NC_M1SS1LE
