10-08-2013, 06:52 PM | #15 | |
Drives: 2010 Cyber Grey Camaro SS (LS3) Join Date: Mar 2010
LOL that's what I just did to my brain.
GPI SS3 Cam / PRC 255 heads / Forged 376ci bottom / Fore level 2 fuel system / D1SC ProCharger on 12lbs / Alky control dual nozzle / 770 whp / 649 wtq tuned by Ryan Stevens at GPI
10-08-2013, 07:32 PM | #16 |
Drives: 2014 SS Join Date: Jan 2011
I'm not sure if that C6 was tuned or not, but they seam to have a more generous dyno based on what I've seen with C7 baselines...
http://forums.corvetteforum.com/c7-t...mes-begin.html |
10-08-2013, 07:56 PM | #17 |
Drives: SS Join Date: Aug 2013
Grand sport dry sump is worth 15hp on its own
10-08-2013, 07:59 PM | #18 |
V8 Lounge member #2
Drives: 2001 Ws6 Join Date: Sep 2009
2001 ws6, 40k miles, Ls3 416 stroker, short block built by PER the rest by me. LPE Ls3 heads milled to 12-1 comp, FAST 102, NW 102, kooks 2", dual DMH cutouts, Magnaflow C/B, BTR cam + springs. Full UMI suspension.
10-08-2013, 08:11 PM | #19 |
Drives: 2012 Camaro SS 45th Join Date: Oct 2011
I thought Chevy used an engine dyno to get their numbers...hence flywheel hp.
OBX 1 7/8 LT's w/high flow cats. Doug Thorley catback w/x pipe. Cold air intake by CAI w/apex scoop.V-max ported throttle body.DynoSpeed tuned by Forest.369 rwhp/385 rwtq
Something wicked this way cometh... |
10-09-2013, 11:01 AM | #20 | |
10-bolt Destroyer
Drives: 2012 Camaro 2SS/RS - AGM, LS3/6M Join Date: Jun 2012
Im aware how a mustang dyno works...but a DYNO in general (no matter WHAT type, brand, etc) can NOT and will not give a real accurate measure just based on weight..it cant take into account the amount of drag the air provides on the car when it's going down the interstate WOT in 4th gear, can it? The weight of the vehicle does not impact the RWHP results NEARLY as much as the weight of the extra rotational mass that a 5th gen has versus a c6 vette. Why would you even try and dispute that? LoL
2012 Camaro 2SS/RS - LS3/TR6060: Cam, Headers, Exhaust, Intake, Gears, Twin Disk, Suspension, Tuned - 475rwhp, 443rwtq |
10-15-2013, 05:37 PM | #21 |
Curious where you came up with that?
Much better systems on 800hp+ NASCAR engines are only worth ~25... http://www.enginebuildermag.com/Arti...g_systems.aspx |
