Vararam
Old 08-01-2013, 10:06 AM   #1
rickr9504
rickr9504's Avatar
Drives: 2018 Camaro 2SS 1 LE
NPP more power?
The new Corvette gets 5hp more with the NPP exhaust. Shouldn't it be the same for the Camaro? I was just wondering.
rickr9504 is offline   Reply With Quote
Old 08-01-2013, 10:13 AM   #2
gajagfan
gajagfan's Avatar
Drives: 2013 1SS 1LE Black - Std Exhaust
I believe dropspeed confirmed 3 HP gains with the NPP.
gajagfan is offline   Reply With Quote
Old 08-02-2013, 11:33 PM   #3
CrystalRedTintcoat
CrystalRedTintcoat's Avatar
Drives: 2013 2SS 1LE NPP GBE
Dude with zl1 at track day asked what I modified on my exhaust. I said nothing. Just NPP.
Sent from my iPad using Tapatalk HD
2013 1LE NPP GBE
Mods
Track Days
CrystalRedTintcoat is offline   Reply With Quote
Old 08-03-2013, 05:46 AM   #4
Dropspeed
2013 Camaro SS1LECTSVZ28
Dropspeed's Avatar
Drives: 2013 AGM 1SS/1LE
Yes sir, despite all of the claims stating there is no difference. This came straight from the mouth of one of the Generals men
Dropspeed is offline   Reply With Quote
Old 08-03-2013, 06:25 AM   #5
Scott@Bjorn3D
Scott@Bjorn3D's Avatar
Drives: Kami, 2013 2SS LS3 Luvin
Send a message via MSN to Scott@Bjorn3D
6HP gain at rear wheels from a GM engineer. Another 5 HP gain from moving away from belt driven power steering.
Scott@Bjorn3D is offline   Reply With Quote
Old 08-03-2013, 07:48 AM   #6
FanDamNCSU
Drives: 2010 CGM 2SS/RS - L99
The NPP exhaust felt a decent bit lighter over stock exhaust as well when I installed mine.
Performance:
Vararam CAI, Vmax Ported Throttle Body, GM Performance Dual Mode Exhaust (NPP), JRE Tune, Hotchkis TVS Stage 2 Track Pack, Vitesse Paddle Shifters, Vitesse Throttle Controller
Functional:
Hex Vents, Elite Catch Can, WeatherTech Digital Fit Mats, Escort Passport Max
Cosmetic:
Heritage Grill, GM Splash Guards, ZL1 Rockers
FanDamNCSU is offline   Reply With Quote
Old 08-03-2013, 08:45 PM   #7
rickr9504
rickr9504's Avatar
That is a huge increase compared to what GM claims.
Old 08-04-2013, 04:41 AM   #8
Scott@Bjorn3D
The car is has been rerated HP in Europe for the electric power steering for 2014. Also look at the dyno pull for 1LE's with NPP close to 400HP stock. My SS with my mods is 402HP at the wheels.
Old 08-04-2013, 12:13 PM   #9
Allgrey
Allgrey's Avatar
Drives: '13 AGM/1SS/1LE/NPP/NAV
That is interesting... The 2014 camaro is rated at 432 hp on the uk website. I don't know if that's a change from the 10-13 in the uk though.
Allgrey is offline   Reply With Quote
Old 08-04-2013, 01:29 PM   #10
2cnd chance
Too Many Great Choices
2cnd chance's Avatar
Drives: Grand Sport/Z07
Is that with NPP or just because of the EPS? I'm guessing it includes no options (no NPP).
2cnd chance is offline   Reply With Quote
Old 08-05-2013, 09:24 AM   #11
rickr9504
rickr9504's Avatar
I believe they do have a different scale when measuring hp. I think the US changed it in 2005. The US uses SAE standard and Europe and japan give measures in bhp (Brake horsepower)
Old 08-07-2013, 12:24 PM   #12
wakespeak
wakespeak's Avatar
Drives: 2020 ZL1 1LE
There is a difference in the European measurement. The formula is:
European rating X 0.9863 = SAE hp.
432 X 0.9863 = 426.
See: http://www.caranddriver.com/columns/...olution-column
Still why would GM go to electric PS if it didn't provide fuel economy/hp benefits. NPP - seems like there would be some benefit similar to the Vette, otherwise loses (some of) its $895 value. I just don't think GM bothered to re-rate the output.
wakespeak is offline   Reply With Quote
Old 08-07-2013, 12:45 PM   #13
rickr9504
rickr9504's Avatar
432 X 0.9863 = 426.
Assuming this is the same engine, the current hp rate is wrong unless it was de-tuned for 2013. From the link you included, the manufacturer has to consider the power steering when doing their measurement, the 2013 models should not have to worry about that anymore so the number should be slightly higher.
From that article also, I am now wondering if the 2013 LS3 engine is SAE certified, or if they ever were?
Old 08-07-2013, 02:33 PM   #14
flyinlow
flyinlow's Avatar
Drives: 2017 Camaro ZL1
GM would only run the motor through the SAE rating if they were going to lose HP. By removing the power steering pump they know that won't happen, they just don't want to go through the process (costs money and it is only a 1-3hp difference anyway). Most vehicles are moving to electric power steering as I believe overall this may be cheaper and longer life (too soon to really tell), and more tunable for steering response. With the electric motor they fine tune steering much better than depending on a hydraulic pump that changes as the engine speed changes, they have to compensate for all of that and its a best effort type of thing. With the electric motor they can feed in accurate speed info as well as steering angles to really fine tune the steering, much easier to do than with a hydraulic pump. The only drawback is more load on the electrical system, that's about it. The way my 1LE drives I forget that it has electric steering until I look under the hood, the steering is very good.
flyinlow is offline   Reply With Quote
