TireRack
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Camaro ZL1 Forum - ZL1 Specific Topics
Old 05-20-2012, 11:10 AM   #1
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '21 ZLE A10
electric power steering failure at 560 miles!!
Of course I will check the basics of the wires and associated fuses first; however, a trip to the dealer may be necessary. I stopped to get gas and when I restarted the car, the steering felt totally unassisted and then the error message of "service power steering". I pressed the ONStar button and they had no info other than to be careful and they saw the same error message on their diagnostics. Darn it
Old 05-20-2012, 11:12 AM   #2
L99CAMA2011
L99CAMA2011's Avatar
Drives: One of the baddest handling Gen 5s
I knew the first ZL-1s were going to have some issue.
L99CAMA2011 is offline   Reply With Quote
Old 05-20-2012, 11:50 AM   #3
ZL1Dave
ZL1Dave's Avatar
Drives: 2012 ZL-1 #1442
Sucks much!! I'm starting to get paranoid about having a steering problem on my car eventually. Hopefully they will zero in on the issue as your not the first to post about having problems with the electric steering. I would expect a TSB about the steering in these cars to show up soon
ZL1Dave is offline   Reply With Quote
Old 05-20-2012, 11:57 AM   #4
2012ZL1
CaRaHoLiC
2012ZL1's Avatar
Drives: '12 ZL1,67 Cam,68 Biscayne 427 4 sp
Rumor was that that was the qc hold up initially.
2012 ZL1
2.55 upper, 10" lower pullies, Innovators west billet hub and sfi balancer, solid blower drive isolator, 50 mm idler kit, full length S/S headers no cats, comp cams custom grind cam, comp roller rocker trunion kit, comp push rods,dual valve springs retainers and locks, Injector dynamics ID850 inectors, Rotofab ZL1 cold air kit, Lingenfelter 160 thermostat, Rotofab intercooler reservoir, stock plugs, LS7 90mm throttle body, GTO clutch reservoir mod, my own custom catch can, Tuning by Jannetty, install by me.
2012ZL1 is offline   Reply With Quote
Old 05-20-2012, 12:15 PM   #5
SIRLOIN
Drives: Ms. Daisy
Man i could only hope something like this wouldn't happen taking an off ramp at a quick pase or something. Could be very dangerous... What about at a roadcourse???
SIRLOIN is offline   Reply With Quote
Old 05-20-2012, 12:20 PM   #6
Modern07
Mid-Florida Camaro Club
Modern07's Avatar
Drives: 2019 ZL1 on Order
This is the 2nd car on here with the same problem
Modern07 is online now   Reply With Quote
Old 05-20-2012, 04:42 PM   #7
MikeOD
Drives: 2010 M6 2SS
If the car is rolling pretty fast, you'd probably barely notice the loss of power assist...it's no big deal having no power steering above 15 mph.
2010 Camaro SS M6. Heads/Cam/Intake/Headers/Exhaust/Suspension
MikeOD is offline   Reply With Quote
Old 05-20-2012, 04:55 PM   #8
KKreme15
KKreme15's Avatar
Drives: C6 Z06
inb4Brandonfromcustomerservice
KKreme15 is offline   Reply With Quote
Old 05-20-2012, 05:53 PM   #9
Uneducated Guess
'12 ZL1 #742
Uneducated Guess's Avatar
Drives: his wife crazy
Uneducated Guess is offline   Reply With Quote
Old 05-20-2012, 06:39 PM   #10
mxkx250
mxkx250's Avatar
Drives: 12 ZL1, 98 Camaro SS, 67 RS/SS
Send a message via Yahoo to mxkx250
I got the same message on my Cobalt SS. Took it to the dealer and they found that a mouse had chewed through the wires. Not covered by warranty. Now I have moth balls under all my cars in the garage.
mxkx250 is offline   Reply With Quote
Old 05-20-2012, 06:43 PM   #11
Stephen12ZL1
Drives: '21 ZLE A10
Ok...I removed the underbelly pan (16 bolts and 2 plastic buttons!) and checked the connections to the power steering going to the rack and tapped on the rack with a plastic hammer. Now, it works but I have no idea if this problem will recur. Nothing seemed loose and no weatherpack connectors appeared to have issues. I will have the dealer check it if I loose power steering again.
Old 05-20-2012, 06:46 PM   #12
L99CAMA2011
Old 05-20-2012, 07:18 PM   #13
Stephen12ZL1
Drives: '21 ZLE A10
disconnect power to the power steering and try it...anything under 10mph was almost impossible to turn. At 70ish mph, it wasn't horrible but still quite an effort. My previous car with power steering failure was much easier to turn (1968 Chevelle).
Old 05-20-2012, 08:27 PM   #14
MikeOD
Drives: 2010 M6 2SS
Just shut the engine off in any car with a power steering pump while you're driving, it's easier than disconnecting stuff...yeah it's different, but it's not like you're suddenly going to drive the vehicle into a wall because of it. Electric power steering is just something that's still kinda new so people are afraid of it...just like electronic throttle's...how many people still think Toyota's actually had a problem? Do you think any of them know the "fix" that was done under warranty involved (for most dealer mechanics who found a faster way to do it than using the Toyota tool) a hack saw blade and some tape? Every model of car will have some examples of problems with every piece of that car...until you actually see a TSB for it, it's just 1 or 2 cars having problems, and I'm sure GM will fix them.
