Old 06-15-2018, 10:17 PM   #15
danhr
BAMF SS
danhr's Avatar
Drives: 2016 Camaro 1SS A8
Send a message via AIM to danhr
Uhhh its GM.... they use as many parts in multiple vehicles all the time. That's what they do.
6.2 that's in the camaro and vette is the same that's in the trucks and suburbans. Theres a few minor differences like intakes,tube, but still the same motor deep down.
Old 06-15-2018, 10:18 PM   #16
JCunningham
JCunningham's Avatar
Drives: 2017 2SS M6
i wish you could get one in a suburban but you cant.
Old 06-15-2018, 10:32 PM   #17
mspeed1LE
mspeed1LE's Avatar
Drives: ZL1 1LE SUMMIT WHITE
Originally Posted by TJay74 View Post
The 6.2L engine in the Corvette/Camaro has no bearing on if the vehicle can tow, it is the car itself that determines that. It is a function of what weight the frame system can handle, are the brakes able to handle the extra load and so on.
The engine in the cars make a little more power and torque than the truck engine and it is just a bit higher in the RPM range, but the car engine is more than up to handling towing.
Which leads me to this question...
https://www.camaro6.com/forums/showthread.php?t=531431
2018 ZLE * StudioRSR Half Cage * SkidmarkGarage Rear Seat Delete * ZL1ADDONS Lift Pads * Roto-Fab CAI * Forgestar CF5-V's * Michelin PS4S * Racequip 6 Pt. Harnesses * Sub-strap Brackets by Carmena Performance * Speedhut Shift Light * Leroy Eng. Hidden Hitch (for the TYR RAT)* Gen5DIY Rapid Flash 3rd Brake Light * KOOKS 2" LT * Green Cats * AWE Cat-back Track Edition *
________________________________________
2005 NISSAN TITAN
1997 BMW E39 (Thug In A Suit) R.I.P. 10/04/18
2002 MAZDA Protege 5 (Time Attack, Hillclimb) SOLD
mspeed1LE is offline   Reply With Quote
Old 06-15-2018, 11:10 PM   #18
JCunningham
Drives: 2017 2SS M6
the hitch attaches to the sheet metal body and its not designed to haul a trailer. its designed to attach a bike rack to.
Old 06-15-2018, 11:22 PM   #19
danhr
BAMF SS
danhr's Avatar
Yes you can. Suburban is getting it for 2019
Old 06-15-2018, 11:30 PM   #20
JCunningham
Drives: 2017 2SS M6
o did not know that about time
Old 06-16-2018, 12:06 AM   #21
SecondZ28
SecondZ28's Avatar
Drives: 2013 ZL1
RST trim will bring the 6.2 to both Tahoe & Suburban
'13 ZL1
'06 TBSS
'98 TJ
'87 GN
SecondZ28 is offline   Reply With Quote
Old 06-16-2018, 12:13 AM   #22
WhyUMad1LE
Drives: 17 SS 1LE
Actually this is not fully correct. The truck 6.2L engine is the exact same as the Corvette/Camaro. Same block, rotating assembly, cam and heads. The only difference on the truck engine is the intake manifold, throttle body and exhaust manifolds.
I thought they had the same throttle body.
Old 06-16-2018, 12:25 AM   #23
JCunningham
Drives: 2017 2SS M6
they do
Old 06-16-2018, 08:38 AM   #24
TJay74
I will have to look later, several of the truck guys have swapped the truck intake over for the Corvette/Camaro intake. I think I remember them saying the TB had to be changed as well. Been a long while since I read the thread about it on that forum.
Old 06-16-2018, 09:28 AM   #25
Jeb114
Jeb114's Avatar
Drives: 2021 300
Exactly as he said.
Jeb114 is offline   Reply With Quote
Old 06-16-2018, 11:18 AM   #26
Ryanbabz71
Ryanbabz71's Avatar
Drives: 2018 Hyper Blue 1SS 1LE
Originally Posted by jdasnt3 View Post
It is an option in the Silverado LTZ 1500 and you can get it in the 2500. Should be an option for the Suburban in 19, I believe.
2500 does not have a 6.2 option
Ryan B.
Ryan
* 2018 1SS 1LE Camaro Hyper Blue Metallic
Car Build: http://www.camaro6.com/forums/showth...0#post10049680
Old 06-16-2018, 11:55 AM   #27
avalonandl
avalonandl's Avatar
Drives: 2019 ZL-1
Ryan B.
Correct the 2500 uses the LS 6.0 truck engine with iron block/Aluminum heads
The LT1 in the Camaro is essentially the same in thee truck as noted above. The intake and exhaust are different along with ecu programming. It is set up for more lower end torque and has a lower peak HP.
Old 06-16-2018, 04:24 PM   #28
NobleSS
NobleSS's Avatar
Drives: 17 Camaro 2SS 50th Anniversary Conv
Originally Posted by Flashyeezus View Post
Do any Chevy trucks etc have that same engine or is it specifically only the c7 and 6th gen ss.
The Chevy SS shares the 6.2L engine although it is discontinued.
2017 2SS 50th Anniversary Convertible,A8,MRC,NPP,NAV,Black Bowties
NobleSS is offline   Reply With Quote
