09-29-2022, 02:46 PM | #1 |
Drives: '86 IROC-Z '18 ZL1 Join Date: Jul 2019
is it safe to drive the car (z1) after header install?
Sorry for the question I know I've seen a few times on a search but I always see conflicting answers.
My exhaust is finally getting delivered today, kooks 1 7/8" no cats to a kooks mid pipe and borla s type mufflers. I'm hoping to have it installed this weekend. I also went and got some new spark plugs, LTR7IX-11 ngk 6510, cause why not. Anywho, the tuner is about 12-14 miles away. Is it OK to drive the car to the shop without hurting anything? I know I'll get check engine lights cause of the no cats. I can take the freeway which is 95% of the travel and just go slow (aka stay out of boost) or should i take the streets and only stick to a max mph? |
09-29-2022, 03:39 PM | #2 |
Drives: E92 BMW M3 Join Date: Oct 2012
Yes, just don't drive it hard and you'll be absolutely fine. I did the same thing in fact.
J-Rod Built and Matt@FSP Tuned |
09-29-2022, 04:20 PM | #3 |
Drives: '16 2SS M6 Join Date: Aug 2019
You have to have the 32 O2 sensor codes turned off before you remove the cats or it will set permanent codes.
David
'16 2SS M6 black on black, SW long tube full exhaust, NPP, Roto-fab CAI, ported stock TB '16 2SS M6 black w/Metallic black stripes, Kalahari, 6 piston front (totaled 1/22/20) '14 Fusion Titanium 2.0T '83 Jeep Wagoneer |
09-29-2022, 04:27 PM | #4 |
Drives: 21 ZL1 Join Date: Feb 2022
Stay out of boost.
