03-12-2021, 08:28 PM | #1 |
Drives: 2015 1le Join Date: Feb 2021
Suede cleaning steering wheel and shifter
Previous owner didn't take very good care of the interior. I worked on cleaning up the suede and found that mother's vlr and scrubbing with a microfiber towel works pretty good at working the dirt out of the suede and making it soft again
03-12-2021, 09:03 PM | #2 | |
Drives: 2014 2SS/RS 1LE Camaro&16 Silverado Join Date: Aug 2013
Sent from my SM-N950U using Tapatalk
Z28 Brake ducts, CAI & Tune
"Never let fear decide your fate!" |
03-13-2021, 11:25 AM | #3 |
Drives: 73 VETTE ,, 05 2500hd diesel,14 1LE Join Date: Feb 2014
It is not suede ,it is synthetic 98% polyester 32% polyurethane . It is in fact called Alcantara ,in other words it is a form of plastic . A stiff brush and some water works fine .
OLD GUY FLYING FAST AND LOW
03-13-2021, 03:22 PM | #4 |
Drives: 2015 Black rs/ss/1le Join Date: Apr 2018
I add a few drops of woolite dark to wam tap water. I soak a micro fiber towel in the solution, wring it out then drape the towel on the wheel for a few minutes to break up the oils and grime. I then gently wipe the area, rinse and repeat.
Once everything is clean, I do a final wipe down with just warm water. Woolite has a slight fragrance that will dissipate after a few minutes. You do not want to apply a lot of pressure when rubbing. |
03-13-2021, 09:57 PM | #5 |
The BBOMG fill-in husband
Drives: 2015 2SS/RS 1LE AKA V1LE Join Date: Aug 2010
I just use a tiny bit of dawn and hot water on a microfiber and get it just barely damp, then dry it with another microfiber which stands the fibers back up and gives it the suede feel again
UPSTATE C5 MEMBER
03-14-2021, 09:36 AM | #6 | |
Drives: 2014 1SS/1LE Join Date: Nov 2015
Sent from my Pixel 5 using Tapatalk
830 WHP 700 WTQ, Whipple 2.9 @ 13lbs Boost, Flex Fuel Tune by Blevins Tuning, LSA SBE, 3.5 GripTec, ATI LS3 Damper, AFR 260cc Mongoose, ARP Studs, Yella Terra Ultralites, Johnson 2110R, BTR PDS Stage 3, Melling 10355, Improved Racing Baffle, ID1050X, DSX Triple Fuel Pump, RotoFab CAI, NW 103mm TB, Stainless Works 1-7/8" LTH to 3" Speed Eng w/ X-pipe to NPP, Powermaster 9509 XS, Detroit Speed Motor Mounts, MGW, Monster LT1-S, ZL1 Calipers, DBA Rotors & Pads, Bilstein B6 Struts & Shocks, BMR 1.25" Drop Springs & Adj Rear Bar, Pegasus Solid Bushings, Z/28 Wheels, other misc parts.
03-14-2021, 09:48 AM | #7 |
Drives: 2014 Camaro SS 1Le Join Date: Feb 2016
I just used a damp rag and went to town. Should really drive the car with gloves on.
2014 SS 1LE Money Pit/ Forged 402
CAM 22X/24X, .619/.617, 113 LSA/ LS9 Heads FIC 1200cc/DSX Aux Pump//McLeod RXT Clutch 730whp: 630Trq |
03-14-2021, 10:43 AM | #8 |
Just wash them dickbeaters
UPSTATE C5 MEMBER
03-14-2021, 12:16 PM | #9 |
03-15-2021, 01:01 PM | #10 |
I always washed my hands B4 driving the car , so mine never got too dirty to begine with.
