Old 09-27-2023, 06:59 PM   #1
NiickySaz
NiickySaz's Avatar
Drives: 2023 Camaro 1LT V6
Bumping up compression to 12.1
Can it be done? I'm trying to find a reasonable dealer who sells 100 octane at a reasonable price/shipping. I don't want to go crazy with the timing.
NiickySaz is online now   Reply With Quote
Old 09-27-2023, 07:05 PM   #2
Gen6cyl
Gen6cyl's Avatar
Drives: Chevy Camaro 2021 ,rs, v6, manual
And raise red line to about 7,800 and maybe bigger cams.
B6 dampers, x pipe, mbrp axel back
Gen6cyl is offline   Reply With Quote
Old 09-28-2023, 12:48 PM   #3
Roostie
all it takes is cash
Roostie's Avatar
Drives: 2018 LS V6 1LE; E350 wagon; Model3
I'm not an expert on engines, so take this with a pinch of salt. To change the compression ratio, you would need new pistons. I don't know if any piston maker is making 12 to 1 pistons for the LGX; if not, you may need an expensive custom set of pistons. Installing pistons requires an engine build. Huge job. Every point of compression buys you about 7% added power. Going from stock 11.5 to 12 to 1 compression will get you perhaps 3 to 4% more power. Not worth the cost, by a long stretch. Perhaps you were just thinking about a custom tune to advance the timing and get a few more hp? You can do that on 93 octane and not need ridiculous, impractical 100 octane.
Best solution if you have money burning a hole in your pocket is to sell your V6 and get an SS. Better yet, enjoy your V6 Camaro as it is, and pay yourself by saving/investing the money, instead of throwing it at aftermarket stuff for the V6 which is likely to be a fool's errand.
Roostie is offline   Reply With Quote
Old 09-28-2023, 01:18 PM   #4
NiickySaz
NiickySaz's Avatar
Yea just trying to work a tune around it, but even then I was just informed it may not even be worth it. Case closed!
Old 09-28-2023, 02:31 PM   #5
Gen6cyl
Gen6cyl's Avatar
I use only premium fuel,93 where I live. Have read it can take up to 1 k miles for the ecu to fully adjust to premium.
Old 09-28-2023, 03:07 PM   #6
Roostie
Roostie's Avatar
I'm glad I said I'm no expert on engines. The more direct effect on compression ratios is the cylinder head. Changing cylinder heads is less work than swapping out pistons. But, it's still a big job. I don't think anyone is building aftermarket heads for higher compression, although some machine shops have modified the stock heads for better airflow. Correct me if I'm wrong. Anyways, head work by itself, without other modifications (to intake, valves, tuning, and headers), is unlikely to yield much power. Plus, going that route will be expensive, difficult to tune, and detrimental to reliability.
