Old 10-12-2023, 10:00 PM   #15
Bumbleboy92
Long hauler
Bumbleboy92's Avatar
Drives: 2022 Camaro 2SS 1LE
Originally Posted by 04DetroitLS View Post
Are those only avail on 1LE or ZL1 too?
6-Pistons are standard on 1LE/ZL1 but it could be optioned on SS's. Refer to my other thread for size information between all the OEM stuff
Did you scroll down
1LZ = LT1 trim
2022 2SS 1LE - Cold Air Inductions Elite Carbon CAI
2016 1LT v6
- Totaled
Happiness: Infinite
Old 10-13-2023, 06:12 AM   #16
04DetroitLS
Drives: 2022 LT1
Originally Posted by Bumbleboy92 View Post
1LZ = LT1 trim
thats what I thought, but then I saw it "fits" so there was a shimmer of hope
04DetroitLS is offline   Reply With Quote
Old 10-13-2023, 10:41 AM   #17
BatMobileLT1
BatMobileLT1's Avatar
Drives: 2023 Camaro LT1 M6
Did you scroll down
Actually, that is the rear brake upgrade that I did try to order before I figured out they won't fit on LT1 (LTZ trim) due to ebrake,...
The link I showed above:
https://accessories.chevrolet.com/pr...5642&year=2023
is actually to 6 piston front brake upgrade that I think might fit.
Just as I noted - I wasn't sure how much functional sense it made to upgrade front brakes from 4 to 6 piston w/larger slotted rotors without being to upgrade the rear brakes at all? Although the $3K+ cost is pretty prohibitive anyway at least for me.
Maybe there is someone who can either confirm that these will fit LT1 and/or comment on whether they would make sense functionally as an upgrade for LT1?
2023 Black LT1 – M6, Dual Mode Exhaust, Sunroof, Tech Pkg w/Bose Audio, Red Front Brake Calipers, Carbon Flash Wheels, Ground Effects & RS Pkg
Added after delivery: Continental ExtCont DWS06+ Tires: 245/40/20 Front & 275/35/20 w/9.5” Rear Wheels, Red Rear MGP Caliper Covers
BatMobileLT1 is offline   Reply With Quote
Old 10-13-2023, 05:00 PM   #18
04DetroitLS
Drives: 2022 LT1
I know you can get the 1le rotors for about 450/500 on rockauto, the cheapest i found the rotors was 1200 :P
still a savings vs dealership...
Most of your braking is done w the fronts, so IDK that rear upgrade is NEEDED... just my .02
