Old 09-15-2022, 09:55 AM   #547
Cyrus
Cyrus's Avatar
Drives: 50th 2SS
Originally Posted by cjperformance View Post
Dealer isn't guaranteed to do it right anyway. Had dealer do mine under warranty. They flushed it once, not 3 times... fixed it for just long enough to get out of warranty, then it came back. Plus found out later, they left it 4-5 quarts low when I had my TC replaced with a stall converter at a performance shop. They expected it to take 1-2 quarts w/ the TC swap... it took 6 qts....
In hindsight, I would have flushed it myself or taken to a reputable shop to get the flush done, then do the tuning change. The setting is in the TCM, so you would need to pull the TCM and send to HPTuners for an unlock. Then pay the license fees for at least the TCM. Not sure if you need ECM too. Anyway, the setting to update is super easy.
I can vouch that the tuning change works, at least for the short term. If you plan on doing other mods, go the tune change route because you'll need everything unlocked anyway. If you don't plan on doing any other tune changes, just do the flush, wait for it to come back, then put a replacement converter in it.
It's a tough choice and it sucks on an otherwise stellar car. I have a 50th also
Hopefully my dealer knows how to do the flush properly. They said they've done serveral trucks already and it seemed to fix the issue. Long term who knows. I also read that letting the car sit for long periods of time makes things worse. Which might explain why I noticed the shudder for the first time on my first drive out of winter storage. Car hadn't moved in 7 months.
As for tuning, what is the recommended tune for these cars ? On my previous 5th gen Camaro I had a "Trifecta" tune installed. Didn't notice a huge difference however it was a manual. I think the tunes work better on the autos. I paid about $600 for mine installed but that was about 4-5 years ago.
50th Anniversary, 2SS, Build#5771, A8, MRC, NPP, NAV, Sunroof, GM Performance CAI, Trifecta Tuned, GM splash guards, Black illuminated bowtie, GM smoked tail lights & third brake light, GM Fifty floor mats, Strut tower brace, JWM side markers, 20% window tint, Sto N Sho front license plate bracket
Cyrus is offline   Reply With Quote
Old 09-15-2022, 10:23 AM   #548
ctrlz
Originally Posted by Cyrus View Post
Didn't think any garage would want to follow the bulletin's instructions. Also, what if that doesn't fix it, at least at a dealership they would be responsible.
I think your best bet is to let the dealership do the fluid exchange and hope it solves the problem.
Unfortunately, if the fix is not permanent, I think the dealer is just going to say you were too far gone and you need a new torque converter.
If you are planning to keep the car a long time, you could also just ask for the price up front to replace both the fluid and the torque converter.
Old 09-15-2022, 09:41 PM   #549
Cyrus
Cyrus's Avatar
Drives: 50th 2SS
Tranny flush is done. No more shudder. Hopefully it lasts I feel like it should I barely put any miles on the car since the issue started. I'll try driving it more than usual the next month to be sure. Only 5-6 weeks away from winter storage.
As per my dash cam, this procedure only took them 1hr 45mins to complete.
Still wondering about a tune. I have the GM CAI which came with its own tune not sure how that effects things.
Old 09-16-2022, 07:26 AM   #550
ctrlz
Still wondering about a tune. I have the GM CAI which came with its own tune not sure how that affects things.
Does this mean you have the GM CAI with the tune already installed, or you are wondering if you need the tune (which dealers will no longer install)?
Either way I think this has nothing to do with transmission/TC issues.
Old 09-16-2022, 01:43 PM   #551
Cyrus
Cyrus's Avatar
Drives: 50th 2SS
Yes I already have the GM CAI installed and tuned. My question was, can I get an after market tune now or will that mess up the computer due to the GM tune.
And yes this has nothing to do with my shudder issue but many have suggested I get a tune now to avoid having the shudder problem return in the future.
Old 09-16-2022, 06:28 PM   #552
A proper tune is custom made for your vehicle, considering whatever modifications you may already have.
Certain generic ("canned" or "boxed") tunes do exist, but I'd steer clear of them as they are almost always suboptimal, catering to the lowest common and safe denominator. I suggest that you work with an actual, experienced tuner on a calibration specific to your car.
In fact, that's exactly what I did.
Old 09-16-2022, 08:09 PM   #553
Cyrus
Cyrus's Avatar
Drives: 50th 2SS
Was thinking this:
https://www.trifectaperformance.com/...#elProductInfo
I worked with one of their reps with my 2010 SS years ago and it was a good expierence.
Gains on a 2017 Camaro V8 are +35 ft-lbs and +40 WHP at the wheels on 91 Octane. Also, the Automatic Transmission gets a Tune to work in unison with the engine’s Tune to optimized performance. Shifting logic is improved and shifts have a more sportier character than Stock.
Will this do anything to help prevent the shudder from returning in the future ?
Old 09-16-2022, 10:22 PM   #554
Was thinking this:
If it properly adjusts the slip tables and/or make pressure adjustments, then probably yes. No idea if they will let you know whether or not this is the case. I haven't purchased anything from Trifecta, but there are others in the forum who did, perhaps they can chime in with their experiences.
For the record, I did try to consult with this company when I had a V6 and they were very "customer unfriendly" to me, but that's just one data point, plus as I said, I strongly prefer an actual professional tuner looking at my actual car and specifically tuning it.
I do know tuners also have templates and base tunes, obviously nobody would want to start from scratch with each customer, but they will also do fine adjustments and make sure everything is optimal. For example, on one occasion Ted Jannetty did a street tuning session with me and adjusted throttle response on the fly based on my actual impressions and requests, you will not get anything like this from a canned Trifecta (or other) tune.
Old 09-16-2022, 10:24 PM   #555
...how I ended up being the resident "level 1 A8 support contact" here, I have no clue
Old 09-26-2022, 11:33 AM   #556
BWoods
Drives: 2017 Camaro RS
Originally Posted by RockerC View Post
did the flush routine @ 15k with no result. TC replaced to no effect. entire transmission replaced under warranty at 20k. GM did not want to pay and claimed that a dyne tune invalidated the warranty. Dealer went to bat for me and trans got replaced but my entire powertrain warranty is now invalid.
Worked fine until two weeks ago at 41k when shudder suddenly started again: unmistakable symptoms once you've had it. Will make appointment with dealer next week.
@RockerC I have the same problem. I had the triple flush and that did nothing, they replaced the TC and shudder was gone for about 3k miles and now it is back. What did your dealer say when you took it in?
BWoods is offline   Reply With Quote
Old 12-22-2022, 05:38 PM   #557
animefan0611
animefan0611's Avatar
Drives: 2017 Camaro 2LT 2.0L Turbo I4
2017 Camaro 2LT 4-cyl with 24k miles here. One month after factory warranty expired, mine developed the transmission shudder. They did the flush per tsb 18-NA-355 and so far seems ok when I drove it home today.
Nightfall Gray Metallic, A8 Trans
22k miles (as of Oct 2021)
2018 Trax LT 1.4L Turbo I4
Summit White, 6 spd Auto
12k miles (as of Oct 2021)
animefan0611 is offline   Reply With Quote
Old 04-12-2023, 05:41 PM   #558
Giri
Soon to be Millionaire
Drives: Blue 2016 Camaro
Mine was fixed under warranty twice and then it ended up shuddering again once the warranty expired. I ended up taking it to a transmission shop that drained and refilled it for an astronomical price
I run a Drone Service Company in Gainesville, FL - Please visit my site and take a look
Giri is offline   Reply With Quote
Old 04-12-2023, 06:02 PM   #559
Bumbleboy92
Long hauler
Bumbleboy92's Avatar
Drives: 2022 Camaro 2SS 1LE
Sounds like a classic case of the torque converter being damaged from the incorrect fluid from factory. The flushes would have fixed it if caught early on but since it kept coming back then they would have had to replace the torque converter. I remember reading they stopped doing that a while back though
2022 2SS 1LE - Cold Air Inductions Elite Carbon CAI
2016 1LT v6
- Totaled
Happiness: Infinite
