05-05-2017, 04:04 PM | #1 |
Drives: 2013 Camaro SS Join Date: Feb 2017
Plug wires
I put new wires on my car and then found the silicone in the box. Should I pull them off and use it or is it necessary?
05-05-2017, 04:25 PM | #2 |
Drives: T Join Date: Mar 2015
if i skipped it and they were already in i wouldnt bother. Probably just electric grease to assist with contact.
05-05-2017, 05:11 PM | #3 |
Drives: 2015 Camaro SS Join Date: Sep 2011
I would as it will make it easier to remove them
later on....
2015 Camaro 2SS Cam/Heads/FBO 498/447 SAE |
05-05-2017, 06:51 PM | #4 |
old school chevy rodder
Drives: 2013 2SS/RS Manual,DM exhaust,CRT Join Date: Jul 2012
dielectric grease. for corrosion prevention and lube.
05-05-2017, 07:59 PM | #5 |
Drives: 2011 1SS/RS IBM Camaro Join Date: Jan 2011
Plus 1
05-05-2017, 11:04 PM | #6 |
Drives: 2015 Camaro 2SS Green Flash Edition Join Date: Dec 2015
I would, especially if it's a daily driver. On other cars I've experienced corrosion on plug ends until I started using dielectric grease.
05-05-2017, 11:04 PM | #7 |
Drives: Several Camaros Join Date: Apr 2016
I would use it. It won't take but 5 minutes. If the wire supplier didn't think it was needed do you think they would include it.
05-05-2017, 11:39 PM | #8 |
Drives: 2015 emerald green ss L99 Join Date: Apr 2017
Use it! Like they said they wouldn't put it in there if it wasn't needed. It keeps you from pulling a wire apart the next time you take it apart. Just twist them first don't pull first. Trust me I know I just had to buy a set of wires for my 6.0 truck because of this so I purchased a big tube of that stuff and I use it on every plug,like injectors everything! Just a small amount keeps out moisture and corrosion and light bulbs too good stuff.
05-06-2017, 09:47 AM | #9 |
Drives: 2012 Camaro SS Transformer Join Date: Sep 2013
Recommend!
I just took my wires off after 36k miles. They came off without damage but it took some wiggling and pulling. Any anti corrosion / anti seize is a good idea on things exposed to the elements. A little time now as compared to potentially more time / money later .... Just s humble opinion but 36 years aerospace engineering.
Mods: trunk subwoofer and amp, LED lighting (fogs, interior, trunk), skip shift eliminator, CAI cold air kit, Vmax ported throttle body, Stainless Works retro chambered cat back, JBA Cat4ward SS ceramic coated headers Potential Next Mods: Tune, F&R sway bars, rear cradle bushing inserts and trailing arms |
05-06-2017, 12:24 PM | #10 |
Got it done this morning, thanks for the replies.
